![]() | Home > Technical > Black Smoke! Getting boring |
| Olly-ibiza Member Since: 23 Aug 2014 Location: Chester/Ibiza Posts: 189 |
Turbos have been done, these pictures are the ends of the inlet manifold where they join on to each bank at the rear of the engine, its the wrong colour to be stem seals, car is in Ibiza till October so cant take it anywhere spiteful Range Rover Sport tdv8 |
| TDV8_AutoB Member Since: 03 Jul 2015 Location: Berkshire Posts: 35
Give Rob @ Rovertune a buzz, + 44 118 950 2777 - explain the car is out of the country and you really need 2 minutes expert opinion. I'll sort him out a drink for you next time I'm in there.
Tried Rob but he suggested all the areas iv checked, only thing left is to remove the ic and check it over properly spiteful Range Rover Sport tdv8 |
| Hussar79 Member Since: 09 Jan 2016 Location: Kent Posts: 6
sorry to make this thread live again , did you get to the bottom of the black smoke ? |
Rocker covers, they have the inlet manifold incorporated in to them and had cracked. So on boost, pressure was getting in to the breather system on over run it was sunking oil out of the Rocker.
thanks for getting back to me, I am having dramas with black smoke on acceleration. been in to 2 different independents land rover specialists and neither could tell me whats up with the poxy motor. Diagnostics are reading no problems and have had the inter-cooler inspected , EGR's are working normal also.
| All times are GMT |
