Home > Technical > Black Smoke! Getting boring
Olly-ibiza
 spiteful Range Rover Sport tdv8
Post #467384 Mon Jul 13 2015 10:34am
Olly-ibiza
Post #467385 Mon Jul 13 2015 10:35am
TDV8_AutoB
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Alaska White
Mmmm, I so want to know what is causing this too.
Is this inlet manifold ? What pipe is this and where is the other end connected to ? (Intercooler or turbo maybe ??)
Have you had the turbos replaced ? - how about a local/friendly Independent centre that you can ask ? If not you could try calling Rob @ Rovertune in Berkshire - he's a helpful guy with oodles of experience that could help.
Valve stem seals ? Turbo oil feed/gaskets ? Intercooler ? Am clutching at straws I know but it seems like you've gone around the usual culprits with a fine tooth comb..........
David
Post #467393 Mon Jul 13 2015 12:44pm
Olly-ibiza
Turbos have been done, these pictures are the ends of the inlet manifold where they join on to each bank at the rear of the engine, its the wrong colour to be stem seals, car is in Ibiza till October so cant take it anywhere spiteful Range Rover Sport tdv8
Post #467471 Tue Jul 14 2015 7:59am
TDV8_AutoB
Give Rob @ Rovertune a buzz, + 44 118 950 2777 - explain the car is out of the country and you really need 2 minutes expert opinion. I'll sort him out a drink for you next time I'm in there.
David
Post #467473 Tue Jul 14 2015 8:06am
Olly-ibiza
Tried Rob but he suggested all the areas iv checked, only thing left is to remove the ic and check it over properly spiteful Range Rover Sport tdv8
Post #467550 Wed Jul 15 2015 7:21am
Hussar79
United Kingdom 2008 Range Rover Sport TDV8 HSE Alaska White
sorry to make this thread live again , did you get to the bottom of the black smoke ?
Post #500073 Sat Jul 02 2016 10:17pm
Olly-ibiza
Rocker covers, they have the inlet manifold incorporated in to them and had cracked. So on boost, pressure was getting in to the breather system on over run it was sunking oil out of the Rocker.
Poo design... like the rest of the car lol spiteful Range Rover Sport tdv8
Post #500074 Sat Jul 02 2016 11:17pm
Hussar79
thanks for getting back to me, I am having dramas with black smoke on acceleration. been in to 2 different independents land rover specialists and neither could tell me whats up with the poxy motor. Diagnostics are reading no problems and have had the inter-cooler inspected , EGR's are working normal also.
i'll have a look into the rocker cover/inlet manifold , glad you got sorted in end anyway.
Post #500094 Mon Jul 04 2016 2:35am
