| RRSPORT.CO.UK | ||
|  | Home > Technical > SRS Airbag light Codes - Cant clear B00D5 B1A00 B1D74 B00DF |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | How did this start ?
|  Wed Jun 29 2016 5:28pm |
| SH0X Member Since: 25 Jan 2016 Location: London Posts: 82      | Hi
|  Wed Jun 29 2016 5:41pm |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | There is a switch panel in the center of the dash.
|  Wed Jun 29 2016 6:36pm |
| SH0X Member Since: 25 Jan 2016 Location: London Posts: 82      | Hi thanks for the info I went out in the middle of the night after reading your post around 3 am and checked - the orange light on the switch pack you mention does come on when you turn on the ignition then goes off and straight after that the red airbag light comes on and stays on.
|  Thu Jun 30 2016 3:06am |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | The codes aren't being cleared.
|  Thu Jun 30 2016 5:39am |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | Do you have the rest of the fault code as there are two digits missing from the end of each one e.g. B00D5-55 also if you changed the switch and have Code B00DF-?? you may have to have it calibrated. See below
|  Thu Jun 30 2016 7:31am |
|  Thu Jun 30 2016 4:27pm |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | Those codes are incomplete you need the other two digits to narrow the fault down, as each of those you listed has at least three codes prefixed buy the first part of the code you listed. I think you may need a Good Indi or Main Stealer to re-calibrate the switch.
|  Thu Jun 30 2016 4:45pm |
| Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407      | If Cheaper or non specific code readers are used, they don't really help when reading codes on the RRS I've found, the IID or IID BT tool are excellent, and do give all the digits on codes found. Not sure of some of the garage equipment, but the Snap on doesn't give good results and that's hardly cheap. John
|  Thu Jun 30 2016 10:30pm |
| SH0X Member Since: 25 Jan 2016 Location: London Posts: 82      | Thanks for the help guys
|  Fri Jul 01 2016 2:12am |
|  Wed Aug 03 2016 2:09am |
| SH0X Member Since: 25 Jan 2016 Location: London Posts: 82      | Update on this , not successfull as yet
|  Tue Aug 30 2016 12:21pm |
| Posting Rules
