![]() | Home > Technical > SRS Airbag light Codes - Cant clear B00D5 B1A00 B1D74 B00DF |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5138
How did this start ?
| SH0X Member Since: 25 Jan 2016 Location: London Posts: 82
Hi
There is a switch panel in the center of the dash.
Hi thanks for the info I went out in the middle of the night after reading your post around 3 am and checked - the orange light on the switch pack you mention does come on when you turn on the ignition then goes off and straight after that the red airbag light comes on and stays on.
The codes aren't being cleared.
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5155
Do you have the rest of the fault code as there are two digits missing from the end of each one e.g. B00D5-55 also if you changed the switch and have Code B00DF-?? you may have to have it calibrated. See below
Hi
Those codes are incomplete you need the other two digits to narrow the fault down, as each of those you listed has at least three codes prefixed buy the first part of the code you listed. I think you may need a Good Indi or Main Stealer to re-calibrate the switch.
| Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407
If Cheaper or non specific code readers are used, they don't really help when reading codes on the RRS I've found, the IID or IID BT tool are excellent, and do give all the digits on codes found. Not sure of some of the garage equipment, but the Snap on doesn't give good results and that's hardly cheap. John
Thanks for the help guys
Hi
Update on this , not successfull as yet
| All times are GMT |
