![]() | Home > Maintenance & Modifications > Removable tow electrics |
| Brutus Member Since: 10 Nov 2015 Location: Cambridgeshire Posts: 67
This might help
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5142
You mean the electric's are unfitted ?
I did mine myself. Quite simple (although I did have the use of a ramp). I didn't need any software update. |
| Gilly1 Member Since: 29 May 2015 Location: Somerset Posts: 203
Yes wiring un fitted.
I seem to have 1 extra wire on my wiring loom, I've circled the wire in red (actual loom) and also circled diagram loom were extra wire is located. Any ideas what/were its for.
Is it a blue/white spade connection ?
It's blue/yellow spade end, yes slightly baffled, Everything the same as on diagram instructions thet Brutus provided but just got the extra blue/yellow. May be why the wiring kit was still in the box and not fitted. |
Is it a 13 pin kit? Single 7 pin or twin ?
BINGO. I found the instructions, It's optional reverse. So if I want to use it there should be a spade end somewere to connect it too. (Maybe, hopefully, ha. )
| All times are GMT |
