Home > Maintenance & Modifications > Removable tow electrics
Gilly1
hi, can any one point me in the direction of a towbar electrics fitting guide, (if there is one) I've just purchased a 2006 hse that has a removable Towbar and the electrics are in a box in the boot 😋 if tried searching forum and got some info ie its plug and play (maybe need software update) but can't seem to find how to guide.
Post #499343 Thu Jun 23 2016 7:36pm
Brutus
England 2006 Range Rover Sport TDV6 Autobiography Java Black
This might help
http://www.pfjones.co.uk/Wiring_instructions/21190501RC.pdf
Post #499383 Fri Jun 24 2016 9:19am
You mean the electric's are unfitted ?
You don't need to program on your early model.
Remove Left rear light
Remove bumper
Spare wheel out.
Fit electrics
Remove passenger side boot trim.
Post #499390 Fri Jun 24 2016 10:29am
Brutus
I did mine myself. Quite simple (although I did have the use of a ramp). I didn't need any software update.
Post #499396 Fri Jun 24 2016 11:08am
Gilly1
Yes wiring un fitted.
Fantastic, that's a great help, thanks all. 👍
Post #499403 Fri Jun 24 2016 12:22pm
Gilly1
I seem to have 1 extra wire on my wiring loom, I've circled the wire in red (actual loom) and also circled diagram loom were extra wire is located. Any ideas what/were its for.
Post #499470 Sat Jun 25 2016 1:15pm
Is it a blue/white spade connection ?
Not seen that before. Maybe it's to power the cars fog lights. Bit of a guess.
Some cars disable the cars rear fog lights when a trailer is connected to stop reflection off a white caravan
Post #499474 Sat Jun 25 2016 2:01pm
Gilly1
It's blue/yellow spade end, yes slightly baffled, Everything the same as on diagram instructions thet Brutus provided but just got the extra blue/yellow. May be why the wiring kit was still in the box and not fitted.
Post #499492 Sat Jun 25 2016 5:11pm
Is it a 13 pin kit? Single 7 pin or twin ?
Does the wire surface at the trailer socket ?
I would just fit it. You can't go too far wrong on the early models. Whistle
Post #499493 Sat Jun 25 2016 5:28pm
Gilly1
BINGO. I found the instructions, It's optional reverse. So if I want to use it there should be a spade end somewere to connect it too. (Maybe, hopefully, ha. )
Post #499494 Sat Jun 25 2016 6:28pm
