![]() | Home > Maintenance & Modifications > Leaky sunroof |
Can't help there, but to make things easier to look up for you, please add your vehicle details in your profile, thanks. |
LJRH Member Since: 22 Apr 2016 Location: Hertfordshire Posts: 209 ![]() ![]() ![]() |
Ah I apologise, I thought I had.
Anyone? |
Probably best to order seals from your Land Rover dealership or better still site sponsor Duckworth parts. Call Dan and give him your VIN number to ensure you are supplied with the correct parts.
I'm unsure if a blocked drain is the issue.
If it is not a blocked drain - which seems to be a very common problem; then the outer seal may have shrunk with age.
And I can order the outer seal by itself? |
Can't be sure but I seem to remember posts on range rovers.net by people who did it.
Thanks for the help! |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5097 ![]() ![]() ![]() |
Try LR023393 only Seal listed for Sunroof.
