Home > Technical > another compressor question |
piedjie Member Since: 18 Apr 2016 Location: Menen Posts: 12 |
I justed checked my compressor and it's already the AMK one. can the suspension fault be caused by the relay? |
Thu May 26 2016 5:15pm |
alpaca Member Since: 09 Sep 2014 Location: Silicon Valley Posts: 83 |
How old is it (years/miles) ? Relay will prevent it from switching on I believe - if it is running slow - you more likely have clogged dryer or worn piston. How long does it run when you first start car ? The time to go from access to normal mode and fault may be due to a number of reasons - but if you have a leak somewhere you would probably see the car settle on one or more comers after leaving it overnight.
Fri May 27 2016 5:01am |
