Home > Technical > another compressor question
piedjie
Belgium 2006 Range Rover Sport TDV6 HSE Santorini Black
what are the benefits of fitting a new compressor? Mine is still working when I want to change the ride-height. If I lower it and put it back to normal height it does so (slowly) and I get a suspension fault that dissappears when I restart. Will the ride quality get better with a new compressor?
thx
Post #497010 Wed May 25 2016 5:35pm
piedjie
I justed checked my compressor and it's already the AMK one. can the suspension fault be caused by the relay?
Post #497083 Thu May 26 2016 4:15pm
alpaca
United States 2006 Range Rover Sport 4.4 V8 HSE Zambezi Silver
How old is it (years/miles) ? Relay will prevent it from switching on I believe - if it is running slow - you more likely have clogged dryer or worn piston. How long does it run when you first start car ? The time to go from access to normal mode and fault may be due to a number of reasons - but if you have a leak somewhere you would probably see the car settle on one or more comers after leaving it overnight.
If the compressor is running overtime it will overheat and eventually burn out - you could try a rebuild kit if you like to diy - else a new compressor is probably on the cards very soon ...
Post #497115 Fri May 27 2016 4:01am
