Home > In Car Electronics > RRS 2008 Harmabn Kardon RAdio Upgrade |
Olly-ibiza Member Since: 23 Aug 2014 Location: Chester/Ibiza Posts: 189 |
Tue May 17 2016 6:02pm |
james115 Member Since: 22 Jan 2015 Location: puglia Posts: 15 |
yes |
Wed May 18 2016 5:30am |
https://incartec.co.uk/Pages/Product.aspx?P=4873
Wed May 18 2016 12:11pm |
So long as your car isn't equipped with Logic 7. |
Wed May 18 2016 12:23pm |
so this is only what i need?
Wed May 18 2016 3:49pm |
terribile i realized i have the logic 7, since i have the amp under the passenger set.
Wed May 18 2016 4:02pm |
Yeah, take your original radio apart till you are just left with the control box, buy some optic fibre and joints, hide the remaining part of the old head unit in the dash and hard wire some iso plugs in to the old harness, you might need a switched live from the fag lighter, you will also need to run your new speaker cables to the amp under the drivers seat and do a bit of wiring in to the speaker wires down there...
Wed May 18 2016 9:40pm |
Fighter3d Member Since: 28 Feb 2015 Location: Martina franca Posts: 44 |
Hello Holly and thanks for help,
Thu May 19 2016 8:10am |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 |
Wait, it's not definitive. I do have an amp under the passenger seat in the RRS, still my system is not a Logic7 (check for Logic7 logo on the speakers AND check your sound settings (♬ icon on the radio, like for the bass/treble controls) for "surround" or "logic7 surround", can't remember exactly). I have it on my Disco and it is clearly visible in the settings. Only if the setting is present it is a Logic7 system. Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
Thu May 19 2016 8:44am |
Really
Thu May 19 2016 8:59am |
So this is definitely all what i need:
Thu May 19 2016 9:02am |
If you have a screen in the top of your dash and you want the satnav to work afterwards you have to do everything I did spiteful Range Rover Sport tdv8 |
Thu May 19 2016 9:28pm |
unfortunately i am not able, i understand i need to disassemble the factory unit, to obtain the control box.
Thu May 19 2016 10:50pm |
Olly please give me an hand
Fri May 20 2016 3:32pm |
