Home > In Car Electronics > RRS 2008 Harmabn Kardon RAdio Upgrade
Fighter3d
Italy 2008 Range Rover Sport TDV6 HSE Bonatti Grey
Hello, i have many problems with the CD player many time it says "Invalid disk" and i would to upgrade the radio system with a new one with bkluethoot and all the new features offered from the new systems, but semmes it is not possible since the radio is fiber optic connected with the overall system
Can you please give me info ?
thanks
Post #496319 Tue May 17 2016 5:20pm
Olly-ibiza
Like this? spiteful Range Rover Sport tdv8
Post #496326 Tue May 17 2016 6:02pm
james115
Italy
yes Shocked
Post #496386 Wed May 18 2016 5:30am
james115
Italy
https://incartec.co.uk/Pages/Product.aspx?P=4873
can i just order this one and have all the original features like the Harmo kardon ?
thanks
Post #496406 Wed May 18 2016 12:11pm
Socast
So long as your car isn't equipped with Logic 7.
Post #496408 Wed May 18 2016 12:23pm
james115
Italy
so this is only what i need?
And can You please suggest a good hifi System to fit in?
not too expensive
thks
Post #496418 Wed May 18 2016 3:49pm
james115
Italy
terribile i realized i have the logic 7, since i have the amp under the passenger set.
i read some post, is there any way to upgrade without loosing
the nav sat screen ?
please reply much appreciated
thanks
Post #496421 Wed May 18 2016 4:02pm
Olly-ibiza
Yeah, take your original radio apart till you are just left with the control box, buy some optic fibre and joints, hide the remaining part of the old head unit in the dash and hard wire some iso plugs in to the old harness, you might need a switched live from the fag lighter, you will also need to run your new speaker cables to the amp under the drivers seat and do a bit of wiring in to the speaker wires down there...
Its a bit of a ball ache but well worth doing.
I went for a JVC touch screen DVD unit with blue tooth as its the one I have in my van and I know where all the buttons are.
Its got outputs for headrest screens and input for reverse camera.
The original speakers are also plop I fitted Focal's in the front and JL in the back, I also sound deadened the doors while they were apart.
I also fitted a sub and hid the amp inside the N/S wall of the boot as its huge in there.
Post #496460 Wed May 18 2016 9:40pm
Fighter3d
Hello Holly and thanks for help,
S0 Do i just need to order these?
Order nr. Order date Product Order status Total Amount
163388 9,56 £
162806 33,24 £
from http://www.kufatec.co.uk/shop/
https://www.kufatec.co.uk/shop/en/accessor...tive-cover
https://www.kufatec.co.uk/shop/en/accessor...r-data-bus
These are the bits you need to order
I have the amp under the passenger seat, no rear camera and all the speakers etcc.
To be honest as my english is not so good i do not understand a word of the rest
Thanks
Post #496487 Thu May 19 2016 8:10am
TheWojtek
Wait, it's not definitive. I do have an amp under the passenger seat in the RRS, still my system is not a Logic7 (check for Logic7 logo on the speakers AND check your sound settings (♬ icon on the radio, like for the bass/treble controls) for "surround" or "logic7 surround", can't remember exactly). I have it on my Disco and it is clearly visible in the settings. Only if the setting is present it is a Logic7 system. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #496489 Thu May 19 2016 8:44am
Fighter3d
Really
no in this case my system is not a logic 7
Post #496490 Thu May 19 2016 8:59am
Fighter3d
So this is definitely all what i need:
thks
Post #496491 Thu May 19 2016 9:02am
Olly-ibiza
If you have a screen in the top of your dash and you want the satnav to work afterwards you have to do everything I did spiteful Range Rover Sport tdv8
Post #496550 Thu May 19 2016 9:28pm
james115
Italy
unfortunately i am not able, i understand i need to disassemble the factory unit, to obtain the control box.
then i need to buy the 2 Bits.
there are some things i do not understand
1) will the sibwoofer work?
2) can the amp be removed
3) can i see the scheem of the connections
4) what other parts do i need ?
5) can i let the control box in the center consolle
6) which facia pannel do i need?
thanks
Post #496565 Thu May 19 2016 10:50pm
Fighter3d
Olly please give me an hand
Thanks.
Post #496613 Fri May 20 2016 3:32pm
