| RRSPORT.CO.UK | ||
|  | Home > General > Lots of squeaking |
| Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003      | Been through any road works ? Stone trapped behind the disc try driving in reverse see if it falls out. 2008 G4 RRSport TDV8 current
|  Fri May 13 2016 8:03pm |
| Cotty Member Since: 16 Apr 2016 Location: Wiltshire Posts: 13    | A stone did enter my thoughts, and done as you suggested.
|  Fri May 13 2016 8:10pm |
| Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003      | Might be a dry joint, see if you can identify which corner. 2008 G4 RRSport TDV8 current
|  Fri May 13 2016 8:13pm |
| Cotty Member Since: 16 Apr 2016 Location: Wiltshire Posts: 13    | I'll get under it tomorrow, and see what's going on.
|  Fri May 13 2016 8:17pm |
| Cotty Member Since: 16 Apr 2016 Location: Wiltshire Posts: 13    | Nothing seems loose, or about to fall off!
|  Sun May 15 2016 6:44pm |
| RichG Member Since: 23 Nov 2012 Location: Adelaide AU Posts: 29      | Mine was making a lot of squeaking when my lower arms were worn out. Front bush and ball joint were ok but the rear hydro-bushes on both arms were completely cactus. Get a pry-bar on the rear bush and test the movement. MY16.5 RRS SDV6 AB Carpathian Grey/black 154k km
|  Thu May 19 2016 3:08am |
| Cotty Member Since: 16 Apr 2016 Location: Wiltshire Posts: 13    | Had it looked at today.
|  Thu May 19 2016 7:27pm |
| Posting Rules
