![]() | Home > General > Lots of squeaking |
| Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003
Been through any road works ? Stone trapped behind the disc try driving in reverse see if it falls out. 2008 G4 RRSport TDV8 current
| Cotty Member Since: 16 Apr 2016 Location: Wiltshire Posts: 13
A stone did enter my thoughts, and done as you suggested.
Might be a dry joint, see if you can identify which corner. 2008 G4 RRSport TDV8 current
I'll get under it tomorrow, and see what's going on.
Nothing seems loose, or about to fall off!
| RichG Member Since: 23 Nov 2012 Location: Adelaide AU Posts: 29
Mine was making a lot of squeaking when my lower arms were worn out. Front bush and ball joint were ok but the rear hydro-bushes on both arms were completely cactus. Get a pry-bar on the rear bush and test the movement. MY16.5 RRS SDV6 AB Carpathian Grey/black 154k km
Had it looked at today.
| All times are GMT |
