Home > Technical > Suspension problem
Cosmo15555
United Kingdom 2010 Range Rover Sport Supercharged HSE Stornoway Grey
Suspension problem
Over the last 4 days I have had the yellow warning light with picture of car and arrows over roof come on 3 times info display telling me normal height only
Could someone let me know any info on this problem
Thanks
Cosmo
Post #495586 Tue May 10 2016 6:55pm
PEACHY
Sounds like the start of EAS compressor failure Big Cry it's located just in front of the near side rear wheel under the body - from start up get someone to lower - raise the suspension from within the cab. A good indicator is a noisy compressor if it struggles to raise quietly it will need more investigation Big Cry but seems likely to be the cause of your issue.
Good luck. Thumbs Up 16MY Estoril Blue SVR.............
Post #495608 Tue May 10 2016 10:46pm
Cosmo15555
Just been looking online and found pump piston repair kit
Is this normally the problem they have
Post #495611 Tue May 10 2016 11:46pm
Frax
Scotland 2012 Range Rover Sport SDV6 Autobiography Santorini Black
If you are really lucky like I was a reset of all fault codes cleared this fault, it was comming in on my one nearly every time I drove it but reset each time I turned the key on and off.
It went to the garage any they cleared out all the old fault codes, that was about 5 months ago and it has never surfaced again.
Hope you are as lucky Smile Lot of Landcruisers now sold
Audi TT 240 Sport now sold for.
RRS 2.7 HSE Now sold for.
RRS Autoibiography 2012
Defender 300tdi 90
Post #495620 Wed May 11 2016 6:40am
Cosmo15555
Not realising it was a problem I have heard the pump working for a while if pump is damaged will it be a garage job or diy as I have mechanic abilities and a iidtool to reset codes
Post #495626 Wed May 11 2016 8:31am
DrRob
Its a DIY job and some good how to guides on Disco 3 forum (same car essentially)....I'm no expert but from my reading its best to get a new one fitted and not try and repair yours.
Hitachi was replaced by a better AMK unit on later cars. AMK can be fitted to earlier cars but they also need a software update IIRC....
Search both forums and gold you will find Thumbs Up * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #495649 Wed May 11 2016 11:15am
CornishRob
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
I have the early type compressor on mine, which had the same issues that you are having. I bought the service kit, and replaced the pump piston ring etc. It's run faultlessly ever since.
The only tricky bit is getting to the top mounting bolt on the compressor mount. I had to tape the bolt to a small socket extension, then managed to feed a small spanner up between the compressor body and chassis to tighten. Oh, and releasing the air pipes needs a bit of practice too Thumbs Up
Post #495735 Thu May 12 2016 8:21am
Cosmo15555
Last night I cleared the fault codes then re wrote flash software to pump and body control ecu suspension semis softer as did get quite stiff feeling bumps more
I will see if light comes on again and if it does I have seen repair kit to repair piston and replace filter in dryer unit
Thank you for all the advice
Cosmo
Post #495779 Thu May 12 2016 5:50pm
Frax
Hope it works for you but do keep us posted. Lot of Landcruisers now sold
Defender 300tdi 90
Post #495817 Fri May 13 2016 6:47am
TheWojtek
DYI. I am planning to do it tomorrow on mine. Bought this kit: https://x8r.co.uk/land-rover-discovery-3-4...d-cap.html (has both all the seals and drier silicone, as well as the upgraded top cap, which very often develops a hairline crack and allows air to escape, resulting in symptoms as described). I plan to follow these guides:
 Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #495830 Fri May 13 2016 10:48am
Cosmo15555
After my post yesterday I took car out and got the yellow light again so ordered repair kit from x8r which is due to arrive on Monday so will let you know how I get on
Post #495895 Fri May 13 2016 8:55pm
TheWojtek
Quick update: I stand corrected.
NOT a DIY job if you have no bloody idea how to properly disconnect the inlet tubes. Which happened to be my case.
Also, 3 of 4 screws that hold the compressor cylinder snapped, making the repair impossible.
Another snapped screw was on the bracket (the one of three holding the actual compressor assembly to the bracket).
Surprisingly, none of the bracket-to-frame screws snapped, the top one (above the compressor) was a PITA, though.
The drier part was kinda easier (make sure to vacuum out the residue), a few things though:
- the upgraded x8r filter has a screw+nut to hold it together, the screw is too short and the metal parts of the filter need to be punched once or twice in order to compress it and allow the nut on the screw.
- the gasket on the excellent aluminium replacement lid is almost too big to fit. You need to carefully position it on the drier and then tighten the screws in sequence, watching the gasket for the proper fit. Takes tens of minutes to do it properly.
So, I'm kinda satisfied, but since I broke (I did it - so it's not x8r's fault) the connectors and snapped the screws, my compressor is being sent for an emergency repair. DAMN ME! Regards etc.,
Wojtek
Post #495985 Sat May 14 2016 3:58pm
TheWojtek
Fixed it.
Combined two compressors into one, fitted it myself (the third screw is by far the most stupid thing I have ever seen on a car). Developed more cuts and bruises in the process. But... it works. No more yellow warning light and "suspension fault normal height only" errors. Regards etc.,
Wojtek
Post #496463 Wed May 18 2016 9:52pm
Cosmo15555
I have removed my compressor but 1 of the rear pipe connections was seised thus the pipe has snapped leaving the insert in the compressor not able to remove
Any suggestions how to sort this problem out
Thanks
Cosmo
Post #496546 Thu May 19 2016 8:53pm
Olly-ibiza
the return pipes I just cut mine off and when refitting just joined them with rubber hoses spiteful Range Rover Sport tdv8
Post #496551 Thu May 19 2016 9:33pm
