![]() | Home > Technical > Suspension problem |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2792 ![]() ![]() |
Sounds like the start of EAS compressor failure |
Cosmo15555 Member Since: 24 Jun 2014 Location: Stevenage Posts: 163 ![]() ![]() ![]() |
Just been looking online and found pump piston repair kit
Frax Member Since: 07 May 2015 Location: Aberdeenshire Posts: 241 ![]() ![]() ![]() |
If you are really lucky like I was a reset of all fault codes cleared this fault, it was comming in on my one nearly every time I drove it but reset each time I turned the key on and off.
Not realising it was a problem I have heard the pump working for a while if pump is damaged will it be a garage job or diy as I have mechanic abilities and a iidtool to reset codes |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2009 ![]() ![]() |
Its a DIY job and some good how to guides on Disco 3 forum (same car essentially)....I'm no expert but from my reading its best to get a new one fitted and not try and repair yours.
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 170 ![]() ![]() ![]() |
I have the early type compressor on mine, which had the same issues that you are having. I bought the service kit, and replaced the pump piston ring etc. It's run faultlessly ever since.
Last night I cleared the fault codes then re wrote flash software to pump and body control ecu suspension semis softer as did get quite stiff feeling bumps more
Hope it works for you but do keep us posted. Lot of Landcruisers now sold
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
DYI. I am planning to do it tomorrow on mine. Bought this kit: https://x8r.co.uk/land-rover-discovery-3-4...d-cap.html (has both all the seals and drier silicone, as well as the upgraded top cap, which very often develops a hairline crack and allows air to escape, resulting in symptoms as described). I plan to follow these guides: Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
After my post yesterday I took car out and got the yellow light again so ordered repair kit from x8r which is due to arrive on Monday so will let you know how I get on |
Quick update: I stand corrected.
Fixed it.
I have removed my compressor but 1 of the rear pipe connections was seised thus the pipe has snapped leaving the insert in the compressor not able to remove
Olly-ibiza Member Since: 23 Aug 2014 Location: Chester/Ibiza Posts: 189 ![]() |
the return pipes I just cut mine off and when refitting just joined them with rubber hoses spiteful Range Rover Sport tdv8 |
