Home > General > Part no.s?
Danv8
United Kingdom 2009 Range Rover Sport TDV6 HSE Lux Alaska White
Part no.s?
Anyone know the correct part no. for a front parking sensor on a 2009 rrs?.
Its the front right (drivers side corner) i need as this morning in a quiet car park i could physically here it not clicking. So just want to have a shop on line before i head off to the dealers later on today.
Thanks
Dan
Post #495818 Fri May 13 2016 7:28am
Is it a late Pre-facelift or a very early Facelift as the sensors are different.
Post #495819 Fri May 13 2016 8:02am
Danv8
i believe its date of first register is 23-1-09 if that's any help.
[URL=]
[/URL]
Post #495822 Fri May 13 2016 9:11am
YDB500301PMA Front and Rear the Same.
Post #495824 Fri May 13 2016 9:30am
Danv8
most appriciated thank you.
Post #495825 Fri May 13 2016 9:40am
Danv8
OK now these guys have them for £29.99 +vat
http://www.lrparts.net/ydb500301pma-parkin...icles.html
Just phoned my local dealership, there price £82.58!!
Surely they can't be that different?
Post #495827 Fri May 13 2016 10:06am
Johnski
Copies are always far cheaper than original LR parts. At the price in link you can't really loose, haven't seen them that cheap before, if genuine, bite their hand off.
Unfortunately including VAT generally around £81.35 (at Rimmers) do come with holder.
http://www.rimmerbros.co.uk/Item--i-YDB500301PMA John
Post #495845 Fri May 13 2016 1:31pm
Disco_Mikey
The cheaper sensors do not have the same range as the genuine sensors. They only start working at 0.7m, instead of 2.5m Thumbs Up
Post #495846 Fri May 13 2016 1:33pm
Just as well you don't need the Bezel/Holder as they are a separate item and another £14.00 each.
I do have a few s/h one's around, if you PM me a address I can post a couple to you to try if it helps, I assume they work ok or else would not have kept them but not really sure. I do have a few Bezel/Holders but there are 4 different one's whether it's o/s, n/s or centre front or on the rear. As you would appear to have HST front bumper and that only has the two Centre one's if I can find a couple will send them as well as they are the same.
Post #495871 Fri May 13 2016 4:57pm
Danv8
Ok I've actually emailed the Land Rover centre to see if they can shed any light on the distance as they are advertising them as oem equipment, so therefor would expect them to work in the same way.
Hopefully if weather warms up and the winds drop here ile have a go at removing the bumper or at least trying to get to the wiring behind the sensor (it's the one you can see below drivers headlight in pic above.) As I'm going to eliminate dodgy wiring first before ordering a new sensor.
Post #495876 Fri May 13 2016 6:12pm
Danv8
Ok I got an reply
Our sensors are made by Valeo who make Land Rover's. They are exactly the same part although one has a Land Rover badge whilst the other doesn't.
So I'm going to order one and see how it goes.£30 is not a lot to loose and if it isn't the sensor at fault, it be nice to ave a spare.
Post #495956 Sat May 14 2016 10:32am
Disco_Mikey
Do,you have a way to check the live values of the PDC once replaced?
Would be interested to see if they read the same as the genuine ones, and truth be told, I'd rather fit OEM to a customers car Thumbs Up
Post #495994 Sat May 14 2016 5:16pm
