![]() | Home > General > Part no.s? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5091 ![]() ![]() ![]() |
Is it a late Pre-facelift or a very early Facelift as the sensors are different.
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 ![]() ![]() ![]() |
i believe its date of first register is 23-1-09 if that's any help.
YDB500301PMA Front and Rear the Same.
most appriciated thank you. |
OK now these guys have them for £29.99 +vat
Copies are always far cheaper than original LR parts. At the price in link you can't really loose, haven't seen them that cheap before, if genuine, bite their hand off.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4505 ![]() ![]() ![]() |
The cheaper sensors do not have the same range as the genuine sensors. They only start working at 0.7m, instead of 2.5m |
Just as well you don't need the Bezel/Holder as they are a separate item and another £14.00 each. I do have a few s/h one's around, if you PM me a address I can post a couple to you to try if it helps, I assume they work ok or else would not have kept them but not really sure. I do have a few Bezel/Holders but there are 4 different one's whether it's o/s, n/s or centre front or on the rear. As you would appear to have HST front bumper and that only has the two Centre one's if I can find a couple will send them as well as they are the same. Cheers Col |
Ok I've actually emailed the Land Rover centre to see if they can shed any light on the distance as they are advertising them as oem equipment, so therefor would expect them to work in the same way.
Ok I got an reply
Do,you have a way to check the live values of the PDC once replaced?
