![]() | Home > Wheels & Tyres > Tyre Wear Question... |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 ![]() ![]() ![]() |
Hi, i am due two new front tyres on the sport, question is they have both worn the inner and outer edges of both tyres evenly, but left quite a bit of meat in the center. I have always kept the tyre pressures checked but any advice would be appreciated, thanks |
CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170 ![]() ![]() ![]() |
When you say checked @ what psi?
Should running 33 front, 36 rear, is the pressure gauge calibrated ? 2008 G4 RRSport TDV8 current
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 ![]() ![]() ![]() |
33 front and 36 rear is only good for light loads (ic max 2/3 people , no lugage, moderate speeds). Max pressure rates are 38 and 42 respectively, but makes the suspension very harsh
The label on my door of RRS has several alternatives for tyre pressures shown for numbers of people weight of rear loads etc with a much wider range of tyre pressures. Could this be for the 2011-2013 facelift models?
Johnski, all Land Rover products since about 2001 have had a plate like that either in the driver's or front passenger's door jam. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 ![]() ![]() |
If they are wearing just on either the inside or outside edge on the same axle, then I'd look at getting the 4 wheel alignment checked as CRACKA suggested.
