Home > Wheels & Tyres > Tyre Wear Question...
Gornal Hills
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
Hi, i am due two new front tyres on the sport, question is they have both worn the inner and outer edges of both tyres evenly, but left quite a bit of meat in the center. I have always kept the tyre pressures checked but any advice would be appreciated, thanks Thumbs Up 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #495338 Sat May 07 2016 5:43pm
CRACKA
Australia 2006 Range Rover Sport Supercharged Bonatti Grey
When you say checked @ what psi?
I have found in the past that what you are describing is caused by under inflation, extreme cornering (not fast just at full lock ) or bad 4 wheel alignment.
So I would recommmend tyre rotation or new tyres with an alignment plus running higher pressures (near the top recommended limit) 2006 4.2 S/C with Tow Pack, Side Steps, DRL's, 19" & 20" wheels, additional 110 ltr Fuel Tank Roof Rack and performance mods.
1952 Rover 75 (Cyclops) First Car !!! Fond memories -was restored-good for 93mph.
Post #495376 Sun May 08 2016 2:58am
Tyrefitter
If it is wearing inner & outer edge then you are running them under inflated.
Andy. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #495382 Sun May 08 2016 7:42am
Camelrock
Should running 33 front, 36 rear, is the pressure gauge calibrated ? 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #495383 Sun May 08 2016 7:48am
Hog
Netherlands 2012 Range Rover Sport SDV6 HSE Lux Buckingham Blue
33 front and 36 rear is only good for light loads (ic max 2/3 people , no lugage, moderate speeds). Max pressure rates are 38 and 42 respectively, but makes the suspension very harsh
In my experience a pressure of 35 front and 38/39 at the back works best.
Post #495407 Sun May 08 2016 5:11pm
Post #495412 Sun May 08 2016 6:27pm
Johnski
The label on my door of RRS has several alternatives for tyre pressures shown for numbers of people weight of rear loads etc with a much wider range of tyre pressures. Could this be for the 2011-2013 facelift models?
Can photograph in morning if it would be of any help? John
Post #495433 Sun May 08 2016 10:45pm
Tim in Scotland
Johnski, all Land Rover products since about 2001 have had a plate like that either in the driver's or front passenger's door jam. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #495442 Mon May 09 2016 8:39am
Russben
If they are wearing just on either the inside or outside edge on the same axle, then I'd look at getting the 4 wheel alignment checked as CRACKA suggested.
Mine did the very same thing until I got it properly aligned via the dealers. It wore through 2 pairs of rear tyres in 2 years because of this & I don't drive it like a hoon.
The local tyre fitting garage couldn't seem to get the settings right despite having the latest hunter laser alignment equipment. For some reason their software was suggesting mine was a 2.7 TDV6 (it's a 3.0 TDV6) too.
If they have both worn on inner & outer edges as you say, then everyone else is probably correct in that the tyre pressures are too low. Either that or you are doing lots of tight turns (in and out of side roads etc). I'm in the shed, I'll be back in the real world in a minute.
Gone- 2010 TDV6; Hello 2017 SDV6.
Post #495474 Mon May 09 2016 2:58pm
