![]() | Home > General > Looking at TDV8 |
V8nutter Member Since: 05 May 2016 Location: Nottingham Posts: 4 ![]() ![]() |
Hi all
Thanks Camel...
Only advice I can give regards looking the car over is apart from bangs and knocks etc is to have aloof underneath as best you can check the DSC pipes for corrosion (so you'll find them on the o/s chassis rail fitted to a valve block level with the drives door) evidence of off road damage though not a deal breaker as this is what they are made for.. 2008 G4 RRSport TDV8 current
At 7 years old is it not due a cam/timing belt change? It isn't up on miles but getting close on elapsed time. Have a look under the bonnet to see if the EGR's have been blanked. Also get hold of the VIN and ask your nearest friendly LR dealer to look up it's service history............. If it has been loved and cherished as is stated then it should have a comprehensive LR service history. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5144 ![]() ![]() ![]() |
TDV8 has a Chain not Belts Tim, so no need to worry about that.
Thanks - where would I find the EGR? |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9144 ![]() ![]() ![]() |
It's unlikely that the EGRs have been blanked as it's a relatively recent thing and requires an engine mapping to do it. 2012 SDV6 - it's missing a couple of cylinders
