Home > General > Looking at TDV8
V8nutter
Looking at TDV8
Hi all
I am going to look at this today
http://www.ebay.co.uk/itm/182102237096?_tr...EBIDX%3AIT
I hear about the turbo failures, but in reality how common is this?
A warranty is definitely a must for piece of mind...
This has full LR service history, but is on 90k miles - but should this be less of an concern regarding turbo failure?
Rich
Post #495236 Fri May 06 2016 8:59am
Camelrock
It's one of those how longs a piece string questions had mine 3 years no problem but others have had. All depends on how you look after ie let engine idle after each run to let them cool done don't over rev from cold, regular oil and filter changes with good quality oil do mine every 5k.. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #495240 Fri May 06 2016 10:15am
V8nutter
Thanks Camel...
I guess its just a matter of biting the bullet... Ill go and have a gander and see if its had any remedial work carried out.
Post #495241 Fri May 06 2016 10:17am
Camelrock
Only advice I can give regards looking the car over is apart from bangs and knocks etc is to have aloof underneath as best you can check the DSC pipes for corrosion (so you'll find them on the o/s chassis rail fitted to a valve block level with the drives door) evidence of off road damage though not a deal breaker as this is what they are made for.. 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #495242 Fri May 06 2016 10:24am
Tim in Scotland
At 7 years old is it not due a cam/timing belt change? It isn't up on miles but getting close on elapsed time. Have a look under the bonnet to see if the EGR's have been blanked. Also get hold of the VIN and ask your nearest friendly LR dealer to look up it's service history............. If it has been loved and cherished as is stated then it should have a comprehensive LR service history. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #495244 Fri May 06 2016 10:47am
TDV8 has a Chain not Belts Tim, so no need to worry about that.
Post #495245 Fri May 06 2016 10:52am
V8nutter
Thanks - where would I find the EGR?
Post #495246 Fri May 06 2016 10:56am
It's unlikely that the EGRs have been blanked as it's a relatively recent thing and requires an engine mapping to do it. 2012 SDV6 - it's missing a couple of cylinders
Post #495279 Fri May 06 2016 4:57pm
