Home > Technical > Uneven tyre wear
Gerd1986
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Santorini Black
Uneven tyre wear
Hi All,
Quick question for you.... My left side front and back tyres are wearing heavily on the outside of the tyres but not the inside the right side is fine.
Any ideas what might cause this? I have only had it a few months after buying it from a LR dealer and seems strange.
2012 autobiography
Cheers,
Gary
Post #495179 Thu May 05 2016 1:25pm
I think I would have a 4 Wheel Alignment Check done first.
Post #495181 Thu May 05 2016 1:28pm
Toe or camber are out. Likely toe and it's both nearside tyres because of the pot-holed state of our roads today. There is a chance that the nearside is running at a different ride height causing an incorrect camber. This is less likely as the front and rear are controlled as axles so to have both go wrong is unlikely. 2012 SDV6 - it's missing a couple of cylinders
Post #495191 Thu May 05 2016 3:46pm
