![]() | Home > Technical > Fault codes |
Jock 77 Member Since: 13 Apr 2012 Location: Falkirk Posts: 187 ![]() ![]() ![]() |
Hi Lads
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4482 ![]() ![]() ![]() |
Suspension code is either a dead compressor, or blown compressor fuse
Thanks Mikey
Sorry the EGR Fault Codes I was meaning.
Hi lads
Generally fault codes have to be cleared, then you can see any new or recurring ones. John
Suspension faults reset with an ignition cycle. If the light is still on, there is still an issue
Sorry lads
As a temporary measure, the compressor will run, and pump the car up if the 60A is replaced with one of the 50A glow plug fuses |
Cheers Mikey
Jock, I have a pile of 9 old compressors and brackets. You are welcome to come up and have a rake through them for a decent one |
Cheers Mikey
I know I'll be there at some point on Monday, my ramp is being delivered |
Cheers Mikey
