Home > Technical > Fault codes
Jock 77
Scotland 2006 Range Rover Sport TDV6 HSE Java Black
Fault codes
Hi Lads
Manged to get the fault codes read on the Sport today after the Amber Suspension Warning light came up for the Suspension the other week.
There was a few Codes that cleared right away ,but 4 that wouldn't any help with how to remedy these would be appreciated.
1. C1A27 Air Suspension short to ground . Which I suspect confirms my Air Compressor is goosed.
2. P0405A
Both 2 and 3 are related to EGR faults, Would blanking the EGR's remedy this ?
3. P140A
4.B1A5618 To do with Traffic Data can't remember full fault details on this one.
Again any help greatly appreciated.
Jock Thumbs Up
Post #494517 Tue Apr 26 2016 10:08pm
Disco_Mikey
Suspension code is either a dead compressor, or blown compressor fuse
Even with blanked EGR's, the codes will always be there. Once blanked, there will be no lack of power anymore
TMC code is logged when it has a poor signal. Very common. Ignore it
Post #494518 Tue Apr 26 2016 10:11pm
Jock 77
Re Fault Codes
Thanks Mikey
Think its definately Compressor as it had been really rattly and vibrating badly before fault light came on after starting. Now only a click at Compressor when started and light comes on.
EGR blanking is on the ' To Do ' list but still not done yet. still okay to run with these fault codes though I take it.
Cheers again for the help
Jock Bow down Thumbs Up
Post #494519 Tue Apr 26 2016 10:20pm
Jock 77
Re Fault Codes
Sorry the EGR Fault Codes I was meaning.
Embarassed
Post #494521 Tue Apr 26 2016 10:23pm
Jock 77
Re Fault Codes
Hi lads
Replaced my Compressor yesterday with a like for like. Turned on the car and the Amber Suspension Warning light is atill coming on .
I am having the Fault codes read again tomorrow to see if it is still C1A27 Air Suspension short to ground Fault that is still up. Would this fault code still hold out the New Compressor until reset by a Diagnostics Machine to protect Electrical Circuit or should it have cleared Automatically and let the New Compressor work right away.
Cheers Jock Thumbs Up
Post #495058 Tue May 03 2016 4:44pm
Johnski
Generally fault codes have to be cleared, then you can see any new or recurring ones. John
Post #495059 Tue May 03 2016 4:47pm
Disco_Mikey
Suspension faults reset with an ignition cycle. If the light is still on, there is still an issue
That code is likely related to a blown fuse, especially considering the way in which the original compressor died Thumbs Up
Post #495062 Tue May 03 2016 5:24pm
Jock 77
Re Fault Codes
Sorry lads
My mistake on closer inspection tonight looks like the 60amp fuse has blown(really need to get new Glasses,it looked ok the other day Embarassed )
Will get a new fuse tomorrow and try again. Just need a new mounting bracket to replace the quite badly corroded old one.
Thanks again for all the help , will update you all tomorrow. Bow down Thumbs Up
jock
Post #495085 Tue May 03 2016 10:02pm
Disco_Mikey
As a temporary measure, the compressor will run, and pump the car up if the 60A is replaced with one of the 50A glow plug fuses Thumbs Up
Post #495086 Tue May 03 2016 10:07pm
Jock 77
Re Fault Codes
Cheers Mikey
Manged to get a new 60amp fuse this morning and fitted it ,Compressor appears to be working fine now Thumbs Up .Although I now have an Airbag warning light on dash that won't clear ,any ideas. Will try and get code read on it today.
Also don't suppose anyone would have a good old style Compressor Bracket thatt they are looking to get rid off. My own is mounting Compressor fine but feel it will need renewed in the not to distant future.
Post #495121 Wed May 04 2016 1:37pm
Disco_Mikey
Jock, I have a pile of 9 old compressors and brackets. You are welcome to come up and have a rake through them for a decent one Thumbs Up
Can plug the car in at the same time, see what the airbag light is Thumbs Up
Post #495125 Wed May 04 2016 2:22pm
Jock 77
Re Fault Codes
Cheers Mikey
Took the car up this afternoon to a Close friend with a garage who had bought a Diagnostics Machine a few months ago and he read codes 2off and then cleared them ,Don't have Codes at hand but it was something to do with Communication and CAN bus.
I am off all next week so will possibly take you up on offer off popping up .I take it you have the Workshop open now ,if so do you have an address and Postcode bud.
Cheers again for all the help to everyone. Bow down Thumbs Up
Post #495140 Wed May 04 2016 8:55pm
Disco_Mikey
I know I'll be there at some point on Monday, my ramp is being delivered Mr. Green
Not too sure on the rest of that week, as the wife will likely still need me, but I'll be there all the following week (16th-20th)
Address is:
Unit 3
42 Baird Avenue
Dundee
DD2 3TN
Turn up the hill at the pink Sidey building, my unit is on the far right at the top of the hill Thumbs Up
Post #495145 Wed May 04 2016 10:13pm
Jock 77
Re Fault Codes
Cheers Mikey
Will give you plenty notice when trying to arrange a trip up.
Post #495149 Wed May 04 2016 11:24pm
