Home > General > Park mode - rotary gear selector
DrRob
Rotary selector used to retract and into park automatically on engine shutdown.
Post recent service it doesn't .....
Weird. Any ideas/ thoughts/comments Thumbs Up * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #493040 Thu Apr 07 2016 12:43pm
DrRob
Can someone please check their 8 speed rotary dials retract if switched off in neutral
Ta
Rob * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Post #493091 Thu Apr 07 2016 9:24pm
Mine used to retract when the ignition was switched off, no matter what gear i was in. Found out by accident once. Shocked It also defaults to P.
Post #493095 Thu Apr 07 2016 9:48pm
Buckster
Mine definitely defaults to park when ignition is switched off and retracts down no matter what gear you are in Rob. Sounds like something is amiss with yours. By all means try the operation of mine on Sunday to see what it should do if you haven't sorted it by then Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #493096 Thu Apr 07 2016 9:53pm
PEACHY
Im a little confused - I lower mine whilst in N then sometimes forget & switch off via the button. The Sport then alerts me the vehicle is not in Park & I have to turn the dial to P which then cancels all alerts & lowers the dial. Rolling Eyes 16MY Estoril Blue SVR.............
Post #493097 Thu Apr 07 2016 10:00pm
I used to lower mine while on approach to my garage. I never did adjust the height while stationary. I was told by my dealer, it is better for the suspension components to do it while coasting.
Post #493100 Thu Apr 07 2016 10:07pm
PEACHY
As per lrtopix
Rotary selector P should normally be selected before switching off the engine. If any other gear is selected at turn off, the selector will move to P before retracting into the centre console.If the engine is switched off with N selected, the system will wait for 10 minutes before selecting P. This time delay allows the vehicle enough time to be conveyed through a car wash Laughing
Ady - I do a bit of both - lowering on approach - or in situ but i like to show off sometimes & lower it if its being admired Rolling with laughter Rolling with laughter Yawn 16MY Estoril Blue SVR.............
Post #493103 Thu Apr 07 2016 10:14pm
DrRob
Perfect, thanks Peachy! That's what its doing so looks like I got myself confused. I can rest easy Thumbs Up * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Post #493117 Fri Apr 08 2016 7:31am
DrRob
PEACHY wrote:
As per lrtopix
Yep, that's what its doing so glad its normal Thumbs Up
Chris - yes, let's check yours out on Sunday before you get it mucky Thumbs Up Rolling with laughter * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Post #493118 Fri Apr 08 2016 7:34am
