![]() | Home > General > Park mode - rotary gear selector |
| DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2026
Rotary selector used to retract and into park automatically on engine shutdown.
Can someone please check their 8 speed rotary dials retract if switched off in neutral
| Buckster Member Since: 05 Mar 2015 Location: Hampshire Posts: 1656
Mine definitely defaults to park when ignition is switched off and retracts down no matter what gear you are in Rob. Sounds like something is amiss with yours. By all means try the operation of mine on Sunday to see what it should do if you haven't sorted it by then |
| PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796
Im a little confused - I lower mine whilst in N then sometimes forget & switch off via the button. The Sport then alerts me the vehicle is not in Park & I have to turn the dial to P which then cancels all alerts & lowers the dial. |
I used to lower mine while on approach to my garage. I never did adjust the height while stationary. I was told by my dealer, it is better for the suspension components to do it while coasting. |
As per lrtopix
Perfect, thanks Peachy! That's what its doing so looks like I got myself confused. I can rest easy * Current: 1974 Lightweight 2.25L petrol. Old skool * GONE: 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8 * GONE: 2011 4.4 TDV8 Full Fat. Amazing piece of kit. * 1949 80" in family since 1975 I use www.glenrands.co.uk Great independent specialist! |
Yep, that's what its doing so glad its normal Chris - yes, let's check yours out on Sunday before you get it mucky * Current: 1974 Lightweight 2.25L petrol. Old skool * GONE: 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8 * GONE: 2011 4.4 TDV8 Full Fat. Amazing piece of kit. * 1949 80" in family since 1975 I use www.glenrands.co.uk Great independent specialist! |
| All times are GMT |
