![]() | Home > General > How do i go about this?.. |
Call them and politely say "They worked 100% before it came for a service".
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
Sounds as though the connector isn't seated correctly, if you remove the offside (drivers) headlight you should be able to see the connector under where the headlight sits. Try cleaning the connection, you can get contact cleaner from Halfords. |
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 ![]() ![]() ![]() |
Thanks for that I have some cleaner already, as its a 5 minute job removing headlight I will give it a try when i get home from work. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4506 ![]() ![]() ![]() |
The bumper does not have to come off, nor do the connections need disturbed
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1054 ![]() ![]() ![]() |
Malfunctioning sensors are a PITA. Spent a long time faffing about trying to fix mine to no avail, so ended up removing the fuse & now I don't get that annoying noise |
Had the same annoying issue on our D4, cleaning the connections worked, but it soon came back. Not a particularly quality unit to be honest. |
