![]() | Home > General > How do i go about this?.. |
| DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2025
Call them and politely say "They worked 100% before it came for a service".
| Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594
Sounds as though the connector isn't seated correctly, if you remove the offside (drivers) headlight you should be able to see the connector under where the headlight sits. Try cleaning the connection, you can get contact cleaner from Halfords. |
| Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378
Thanks for that I have some cleaner already, as its a 5 minute job removing headlight I will give it a try when i get home from work. |
The bumper does not have to come off, nor do the connections need disturbed
| Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1058
Malfunctioning sensors are a PITA. Spent a long time faffing about trying to fix mine to no avail, so ended up removing the fuse & now I don't get that annoying noise |
| Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796
Had the same annoying issue on our D4, cleaning the connections worked, but it soon came back. Not a particularly quality unit to be honest. |
| All times are GMT |
