![]() | Home > Faults & Fixes > Front parking aid inactiveI the |
Jock 77 Member Since: 13 Apr 2012 Location: Falkirk Posts: 187 ![]() ![]() ![]() |
Thanks very much again Bud ,Will let you know how I get on. |
denlaa Member Since: 09 Mar 2015 Location: Banbury Posts: 7 ![]() ![]() ![]() |
Hi, yeah that's no problem. I have about 3 sensors left so just let me know what you need.
Billyblue02 Member Since: 16 Aug 2015 Location: Shropshire Posts: 5 ![]() ![]() ![]() |
Any advice on listening for the clicking sensors on a 12 plate as I can only do it with the engine running ( cos of the retracting gear nob) can't hear cos of engine at front exhaust at rear ?? |
Citizen55 Member Since: 14 Dec 2015 Location: Rollin' in my Five point O (well, 4.2) Posts: 55 ![]() ![]() ![]() |
Stethoscope ?
ragpicker Member Since: 21 Mar 2016 Location: Teesside Posts: 47 ![]() ![]() ![]() |
Sorted mine. In the end it was the drivers side corner one.
MrGimper Member Since: 05 Jun 2016 Location: Andover Posts: 57 ![]() ![]() ![]() |
Did you pull it out the front of the bumper, or did you push it thru back into the bumper? I can't work out which way to go. |
Hi there from what I remember I pulled them out from the front of the Bumper. Think they had a couple of small legs that need pushed in to do this though.
Thanks for replying. In the end I managed to remove the headlight and get a bar down to lift a clip and then use a punch to knock it back into the bumper. I still have the scars! |
foxy69 Member Since: 30 Apr 2017 Location: Swansea Posts: 13 ![]() ![]() ![]() |
Gday all, thanks for all the helpful tips on here. I have the inactive parking sensors message on my dash. I have changed the front off side sensor and now they are all clicking front and back but I am still getting the message and flashing switch on the dash. I have just replaced the battery and now disconnected it to see if that will clear the fault??
