![]() | Home > Faults & Fixes > Front parking aid inactiveI the |
Jock 77 Member Since: 13 Apr 2012 Location: Falkirk Posts: 187 ![]() ![]() ![]() |
Hi lads
Need to check the sensors, when one of the front goes faulty, the rears will also stop working.
Thanks Bodsy
Hi Lads
Hi there
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4502 ![]() ![]() ![]() |
Front outer sensors can be done via the fog light hole |
Thanks for that info Mikey
Outer sensors should be angled too, but straight sensors do fit, and work fine
Thanks Mikey
SH0X Member Since: 25 Jan 2016 Location: London Posts: 82 ![]() ![]() ![]() |
Guys I saw powerful uk show how to detect the faulty sensor - listen out for a click from each sensor- if no clicking its a duff sensor - have the car running
Cheers for the reply
denlaa Member Since: 09 Mar 2015 Location: Banbury Posts: 7 ![]() ![]() ![]() |
Hi Jock, you are right, the pre 2010 cars have the straight sensors which are much larger than the later ones which are right angled. I had problems with my system playing up last year and ended up replacing all of my sensors, the front wiring loom, which was the faulty part, and the parking module. I have 4 of these genuine sensors and the loom, as I have just fitted a new bumper which came complete. I can send you a sensor out and if it fixes your problem you can just send me a tenner, if it doesn't just pop it back in the post. ( Hope this doesn't breach any rules). |
Hi Bud
Hi John, no problem at all mate, hopefully you won't need it but the same offer is there for the loom if you do. I spent £500 getting them all working again just for them to annoy the |
