![]() | Home > General (L494) > SVR tire replacement question |
| Renaco Member Since: 28 Jul 2011 Location: Bavaria Posts: 325
Usually, change axle wise...! |
| DaveW Member Since: 14 Nov 2013 Location: Warwickshire Posts: 283
As you've around 1/4" or 6mm you'll be fine with one tyre. Incidentally, as you're on aftermarket rims, what tyres are you running anyway? |
| MafroSVR Member Since: 18 Feb 2016 Location: New York Posts: 49
I am running the 275/40 R22 Cross Contact Continentals. |
| Cantona Member Since: 27 Oct 2015 Location: Cheshire Posts: 518
How are the pics coming along Mafro?! |
Working on it my friend. Flat tire and inclement weather has been daunting. Hopefully this weekend. Isn't your car due soon? |
Also, see that I just had my flat last week, I did notice there is a spare in the car under the rear loading area. Is the car spec'd for performance with or without that spare? Can I remove it? Will it make a difference? |
Depends on if it is a full size or space saver Mafro. Space savers are limited not only to speed (in UK supposed to be 50mph) but also to range (IIRC 50miles). If it is a full size or reduced section then IIRC LR calculates the rolling diameters to be the same size so you can use it longer and faster. IIRC space savers come with a load of yellow markings on the wheel to make them highly visible when in use too. I'm not 100% certain of above so expect to be corrected. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Wednesday is the day |
I'm sorry. I should clarify. I want to take it out so I no longer am carrying the weight, and was wondering when they designed and engineered the SVR if it included the space saver spare or not. I don't want to take out the spare if it is part of the balance of the vehicle, etc. Sorry for the confusion. |
I am very excited for you! Perhaps we will post pics on the same day! HA! Enjoy your delivery!! |
Although not hugely heavy the weight of the spare should be detected by the air suspension and due allowance made in the ride settings. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Think I might take a sleeping pill tonight |
I'm going to take it out and see if I notice a difference. It would be good to hear if DaveW has an opinion on this but I appreciate the feedback Tim. |
You will probably need it. But with the collection you have I am surprised you are not addicted to sleeping pills yet. |
