![]() | Home > General > Belts change help. |
Reidspeed in Hinkley. |
| beads Member Since: 26 Mar 2016 Location: bagshot Posts: 18
id be interested on how much you are able to get it done for,
| mrobin53 Member Since: 30 Mar 2016 Location: derbyshire Posts: 2
Have had a quote from independant landrover specialist for £870, he tells me the oil pump doesnt always need changing but would check it, he reckons the biggest reason oil pumps sometimes fail after belts have been changed is because it hasnt been torqued off properly when putting back together |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9156
The oil pump failure appears to be due to a change in design of the housing. The failing one is a weaker design and LR reverted to a stronger one as a result of the failures. Got to be worth having it done at the same time as the belts; they seem to fail soon after the belt change if they are going to fail. 2012 SDV6 - it's missing a couple of cylinders
| Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477
At least it's simple(ish) to do on the V6. The TDV8 oil pump is an engine out job I think. So that's body off too. 2012 SDV6 - it's missing a couple of cylinders
| All times are GMT |
