Home > General > Belts change help.
mrobin53
England 2006 Range Rover Sport TDV6 HSE Stornoway Grey
Belts change help.
just bought my first rrs so thought i would join a forum with rrs owners and hopefully experts i can turn to for hints and tips on looking after my motor,am looking for an independant 4x4 specialist in the Leicestershire/Derbyshire area that i can go to for belts and oil pump change, my car is a RRS HSE 2.7 06 plate with 94 on the clock, full service history, one owner, nothing in service book to tell me belts have been done, any help much appreciated. Very Happy
Post #492283 Thu Mar 31 2016 8:35am
Bodsy
Site Sponsor
Reidspeed in Hinkley. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #492284 Thu Mar 31 2016 8:39am
beads
United Kingdom 2007 Range Rover Sport TDV6 SE Siberian Silver
id be interested on how much you are able to get it done for,
mines going in on the 11th
Ive been quoted just over 1k to have
the two belts done, all the gibbons which go with it.
water pump,
auxiliary belt,
oil pump/casing ?
i said oil casing, they said oil pump are these the same part or is the casing totally separate? ? as he said 200+ for the oil pump.
Post #492324 Thu Mar 31 2016 4:13pm
mrobin53
Have had a quote from independant landrover specialist for £870, he tells me the oil pump doesnt always need changing but would check it, he reckons the biggest reason oil pumps sometimes fail after belts have been changed is because it hasnt been torqued off properly when putting back together
Post #492710 Mon Apr 04 2016 11:12pm
The oil pump failure appears to be due to a change in design of the housing. The failing one is a weaker design and LR reverted to a stronger one as a result of the failures. Got to be worth having it done at the same time as the belts; they seem to fail soon after the belt change if they are going to fail. 2012 SDV6 - it's missing a couple of cylinders
Post #492735 Tue Apr 05 2016 8:45am
Lost for Words
Important to note, however, that it has also occured with the other pump types, so the recommendation to change it applies to all years. Thumbs Up Visiting from DISCO3.CO.UK
Post #492737 Tue Apr 05 2016 8:52am
At least it's simple(ish) to do on the V6. The TDV8 oil pump is an engine out job I think. So that's body off too. 2012 SDV6 - it's missing a couple of cylinders
Post #492769 Tue Apr 05 2016 12:20pm
