Home > General > 2010-2014 Headlights AFS or Not
mnk
Thinking of purchasing facelift LED headlights to replace my 2006 AFS to complete a full facelift. My questions is, were all headlights on facelift models AFS spec?
Post #492629 Sun Apr 03 2016 10:12pm
Lost for Words
No. Also bear in mind that the conversion with AFS lights has proved to be hit and miss (and no-one has been able to pinpoint the deciding factor) - you may find they won't work. Thumbs Up Visiting from DISCO3.CO.UK
Post #492638 Mon Apr 04 2016 7:45am
mnk
Thanks for the response LOW. Is it still a hit and miss even if my 2006 has AfS from factory?
Post #492640 Mon Apr 04 2016 8:36am
Lost for Words
Yes, 'fraid so. The ECU communicates with the lights by LIN bus, and it seems some modules will communicate and others won't, and as yet, I don't think anyone has found the link as to why. The pre- and post-facelift models use differen't CANBUS bitrates, which means the ECUs aren't cross-compatible, so it's down to whether the lights work with the existing ECU or not. Thumbs Up Visiting from DISCO3.CO.UK
Post #492643 Mon Apr 04 2016 8:59am
mnk
thanks buddy Thumbs Up
Post #492644 Mon Apr 04 2016 9:16am
Guyzer73
Oman 2006 Range Rover Sport Supercharged Vesuvius Orange
mnk,
Can only confirm LfW statements. I got Valeo 2012 headlights with AFS and try as I may the AFS doesn't work. On the other hand I think Peachy did a full conversion using OEM headlights on his 2006 and the AFS function worked. Go figure.... Truly hit and miss.
Guy 2006 RRS S/C CONSTANTLY under modification...
1994 RRC 4.2l not LSE sadly gone but not forgotten
LR Defender 300Tdi - affectionately know as "The Black Beast"
Post #492715 Tue Apr 05 2016 6:22am
mnk
Thanks guyzer,
If and when I do fit the facelift AFS headlights, how will I know the AFS function works while the car is stationary?
Post #492724 Tue Apr 05 2016 8:42am
Guyzer73
Mnk,
Firstly, if not working you'll get an error and dash warning light illuminated. If it works when you turn on the ignition the headlights should do a little dancer alignment.
Post #492726 Tue Apr 05 2016 8:56am
mnk
Thanks Guy, I'll let you know how I get on.
Post #492727 Tue Apr 05 2016 9:00am
