![]() | Home > In Car Electronics > Upgrading 2012 screen to Dualview unit possible? |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5154
The Hardrive is a Integral part of the Screen Unit. Whether it can be upgraded or not wouldn't know but would be inclined to think not.
| bitcrunch Member Since: 28 Mar 2016 Location: UK Posts: 16
Thanks for your response Col. Id like to give it a try, im a computer engineer by trade and delve alot into circuitry so I might investigate further and see what i can do.
| Autobiography Member Since: 19 Jun 2012 Location: Londres Posts: 339 |
The 2012 Range Rover Sport was not available with Dual View. The only Dual View in the previous generation was on the L322 from 10MY.
| PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796
Really? Then I stand corrected. Apologies. |
| wireworld Member Since: 23 May 2014 Location: Shropshire Posts: 45
I had a 2013 RRS Black edition with dual view |
Thanks for the input guys, i think ive found a dual view screen so once that arrives ill have a go at installing it and also trying to swap out the hard drive for an ssd to hopefully speed things up on the infotainment.
Don't forget - you also need to change the fascia - buttons under the screen |
I have a 2012 RRS and the dual view screen should be exactly the same using the same fascia? Are you refering to the 2005-2008 dash peachy?
In a Vehicle without Dual Screen it has a button on the dash which has Setup on it, in a Dual Screen vehicle this button has a Icon on it of in effect Two Screens on it.
Check that the crashed one had Dual View as this was a Option not Standard Fit, although I believe it may have been in the Black Edition as Standard Fit. I'm afraid Peachy is right as there are different Part Numbers for the switch panel be it Dual View or Not. Cheers Col Last edited by Col on Tue Mar 29 2016 5:40pm. Edited 1 time in total |
| TPS Member Since: 12 Oct 2015 Location: Buckinghamshire Posts: 127
Really interested to know if a straight swap will work. I presume the Config will need to be updated to enable the dual screen. Wonder if that config change also alters the function of the setup button?
Soon as i recieve the screen ill take some pictures as i progress. Im hoping the screen That was sold to me was a dual screen as thats what i was told.
| Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407
I have the dual view on MY2012 RRS SDV6 HSE Lux and there is indeed a different button/switch for dual screen (not to be confused with the motorway junction readout and map which looks like a dual screen), I believe you will find there is a different control board for this setup, not just a switch change over I'm afraid. Details of both systems were in my owners handbook, which came with the car. John
