Home > In Car Electronics > Upgrading 2012 screen to Dualview unit possible?
Page 1 of 3 123>
bitcrunch
Hi guys, Ive been reading up on this forum alot and recently bought a 2012 HSE that doesnt have dual view and was wondering whether its possible to just swap out the existing screen for a dual view one without any issues?
Also how can i tell what unit has dual view? Ive seen some screens on ebay but no idea whether they are dual view or not.
Another thing I was thinking of doing was to speed up the loading on the infotainment I was looking to find where the hard disk was located and try to put an ssd in place to hopefully speed things up.
any input would be great thanks guys.
Post #492012 Mon Mar 28 2016 10:25pm
The Hardrive is a Integral part of the Screen Unit. Whether it can be upgraded or not wouldn't know but would be inclined to think not.
Post #492015 Mon Mar 28 2016 10:47pm
bitcrunch
Thanks for your response Col. Id like to give it a try, im a computer engineer by trade and delve alot into circuitry so I might investigate further and see what i can do.
Would just like to know how I can identify a dual view screen by model number or connections at the back and whether its a straight swap over from the standard screen without any modifications then i can hopefully get one and see about swapping out the hard drive.
Also where did you get all that for the RSE from?
Post #492018 Mon Mar 28 2016 10:59pm
Autobiography
The 2012 Range Rover Sport was not available with Dual View. The only Dual View in the previous generation was on the L322 from 10MY.
The angle and location is wrong for the dual view to work effectively, hence why it was not offered on the L320 RRS and still isn't on D4
Post #492079 Tue Mar 29 2016 2:41pm
PEACHY
Shocked mine has dual view - registered 31 March 2012 Shocked 16MY Estoril Blue SVR.............
Post #492081 Tue Mar 29 2016 2:57pm
Autobiography
Really? Then I stand corrected. Apologies.
Post #492082 Tue Mar 29 2016 2:58pm
wireworld
I had a 2013 RRS Black edition with dual view
Post #492087 Tue Mar 29 2016 4:09pm
bitcrunch
Thanks for the input guys, i think ive found a dual view screen so once that arrives ill have a go at installing it and also trying to swap out the hard drive for an ssd to hopefully speed things up on the infotainment.
Will let you guys know how i get on once everything arrives.
Post #492089 Tue Mar 29 2016 4:23pm
PEACHY
Don't forget - you also need to change the fascia - buttons under the screen Thumbs Up
Good luck Thumbs Up 16MY Estoril Blue SVR.............
Post #492090 Tue Mar 29 2016 4:27pm
bitcrunch
I have a 2012 RRS and the dual view screen should be exactly the same using the same fascia? Are you refering to the 2005-2008 dash peachy?
Also does the screen need pairing to the car or does it just work outta the box? its a used one pulled from a crash damaged RRS 2012 so hopefully its all working good.
Post #492099 Tue Mar 29 2016 5:00pm
In a Vehicle without Dual Screen it has a button on the dash which has Setup on it, in a Dual Screen vehicle this button has a Icon on it of in effect Two Screens on it.
If you wish can post picture of dash as I have Dual Screen as well.
Post #492101 Tue Mar 29 2016 5:08pm
Check that the crashed one had Dual View as this was a Option not Standard Fit, although I believe it may have been in the Black Edition as Standard Fit.
I'm afraid Peachy is right as there are different Part Numbers for the switch panel be it Dual View or Not.
Post #492103 Tue Mar 29 2016 5:24pm
TPS
Really interested to know if a straight swap will work. I presume the Config will need to be updated to enable the dual screen. Wonder if that config change also alters the function of the setup button?
Would be really good if you can take pictures along the way to show the process steps taken. This can also help with support should it be more complex than expected. -----------------------------------------------
RRS SDV6 HSE MY2012 Orkney grey, Oxford leather Ivory seats Ebony carpet, Anigre wood trim, enhanced design pack.
Post #492106 Tue Mar 29 2016 5:34pm
bitcrunch
Soon as i recieve the screen ill take some pictures as i progress. Im hoping the screen That was sold to me was a dual screen as thats what i was told.
My dash has the setup button by the mode knob which i guess thats what your referring to.
Hopefully it is a straight swap over and the setup button then becomes the dual view button but once i recieve the unit ill have a play about and see.
Does anyone know what the rear of the dual view screen or model number should be? the one i bought has the model number of 3Q9GS2003 and is manufactured by bosch.
Post #492108 Tue Mar 29 2016 6:32pm
Johnski
I have the dual view on MY2012 RRS SDV6 HSE Lux and there is indeed a different button/switch for dual screen (not to be confused with the motorway junction readout and map which looks like a dual screen), I believe you will find there is a different control board for this setup, not just a switch change over I'm afraid. Details of both systems were in my owners handbook, which came with the car. John
Post #492111 Tue Mar 29 2016 6:44pm
Page 1 of 3 123>
