| RRSPORT.CO.UK | ||
|  | Home > General > Start Stop button |
| PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796    | Welcome to the forum   | ||
|  Tue Mar 15 2016 8:44pm |
| Relayer Member Since: 05 Mar 2016 Location: Norfolk Posts: 6    | Ewoke is an auto | ||
|  Tue Mar 15 2016 8:47pm |
| PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796    | Just copied this from the owners manual -
|  Tue Mar 15 2016 8:58pm |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | I just put my foot on the brake pedal then press stop/start button, haven't really noticed any delay in starting.
|  Tue Mar 15 2016 9:05pm |
| PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796    | Just tried pressing button once as per above but nothing - the Sport will not start unless the button stays pressed & the brake pedal is pressed - i wait for the "checking system" message to finish which then prompts the brake pedal message   | ||
|  Tue Mar 15 2016 9:10pm |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | Hi Peachy , yeah mines the S/C.
|  Tue Mar 15 2016 9:24pm |
| BiffoBear Member Since: 23 Feb 2016 Location: Bucks Posts: 51    | Before getting my Sport (diesel, auto), I had an Evoque (diesel, auto) and that started with just a quick press and release of the button. The Sport is definitely different and needs the button to be held in for longer. Took me a few weeks to get used to it after the Evoque.
|  Tue Mar 15 2016 9:47pm |
| Mr Rusty Member Since: 17 Jan 2016 Location: Aberdeen Posts: 376      | Yeah mine is the same, slight delay in starting. I guess it depends on temp as glow plugs need to heat.
|  Tue Mar 15 2016 9:51pm |
| gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961      | As above,, there is a delay on mine but as has been said, it's dependant on temp, as long as you keep the brake pedal pressed it will start with just a momentary press. When stopping I can press the button without being in the car and it's stops straight away 2010 RRS, TDV8
|  Wed Mar 16 2016 12:52pm |
| Buckster Member Since: 05 Mar 2015 Location: Hampshire Posts: 1656      | As above with the delay on mine, when in the Alps in January in some very cold temps of -14 there was a noticeably longer delay, where I would think that it heated the glow plugs for longer due to temperature first thing in the mornings   | ||
|  Wed Mar 16 2016 1:12pm |
| Relayer Member Since: 05 Mar 2016 Location: Norfolk Posts: 6    | Thanks for all your comments but thought I'd give an update.
|  Wed Mar 23 2016 2:15pm |
| DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2026    | The rear cabin lights on the C pillar are manual switched only. Annoying but that's how they come out of the factory   | ||
|  Wed Mar 23 2016 4:30pm |
| Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407      | I've been told there is a Mod on here for having all the lights come on/off together, but you have to do a bit of soldering (no problems there) but I'm   | ||
|  Tue Apr 05 2016 10:02pm |
| Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407      | Further to above post, member kindly posted up the link, think I'm going to do this anyway this weekend.
|  Tue Apr 05 2016 10:12pm |
| Posting Rules
 is the ewoke ( Evoque ) a manual or automatic ?
 if I can find it so far.
