![]() | Home > General > Start Stop button |
| PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796
Welcome to the forum |
| Relayer Member Since: 05 Mar 2016 Location: Norfolk Posts: 6
Ewoke is an auto |
Just copied this from the owners manual -
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156
I just put my foot on the brake pedal then press stop/start button, haven't really noticed any delay in starting.
Just tried pressing button once as per above but nothing - the Sport will not start unless the button stays pressed & the brake pedal is pressed - i wait for the "checking system" message to finish which then prompts the brake pedal message |
Hi Peachy , yeah mines the S/C.
| BiffoBear Member Since: 23 Feb 2016 Location: Bucks Posts: 51
Before getting my Sport (diesel, auto), I had an Evoque (diesel, auto) and that started with just a quick press and release of the button. The Sport is definitely different and needs the button to be held in for longer. Took me a few weeks to get used to it after the Evoque.
| Mr Rusty Member Since: 17 Jan 2016 Location: Aberdeen Posts: 376
Yeah mine is the same, slight delay in starting. I guess it depends on temp as glow plugs need to heat.
| gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961
As above,, there is a delay on mine but as has been said, it's dependant on temp, as long as you keep the brake pedal pressed it will start with just a momentary press. When stopping I can press the button without being in the car and it's stops straight away 2010 RRS, TDV8
| Buckster Member Since: 05 Mar 2015 Location: Hampshire Posts: 1656
As above with the delay on mine, when in the Alps in January in some very cold temps of -14 there was a noticeably longer delay, where I would think that it heated the glow plugs for longer due to temperature first thing in the mornings |
Thanks for all your comments but thought I'd give an update.
| DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2025
The rear cabin lights on the C pillar are manual switched only. Annoying but that's how they come out of the factory |
| Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407
I've been told there is a Mod on here for having all the lights come on/off together, but you have to do a bit of soldering (no problems there) but I'm |
Further to above post, member kindly posted up the link, think I'm going to do this anyway this weekend.
| All times are GMT |
