Home > General (L494) > Hot Spot on dash / centre console
les2802
Has any one else noticed that the top of the centre console is getting hot after a longish journey ?
There is an area about 10cm round that starts to warm up after about 15minutes and by the time I arrive at work ( 1hour) it is very warm / hot. All round it is still cold.
I have run it with the heating down in case it was a vent pipe and no change . thought I would check to see if this was 'normal' before going back to the dealer
Post #422827 Wed Apr 30 2014 8:57am
kilsbm
2010 Range Rover Sport 3.0 TDV6 HSE Ipanema Sand
I have exactly the same
Did you figure out if this is a fault or not ?
Cheers,
Matt
Post #490196 Sun Mar 06 2016 9:50pm
fkarim
This was mentioned in more recent posts. Mine also does it but I haven't got it looked at yet. Another member had his sorted as a side effect of a different fix: http://www.rrsport.co.uk/forum/post481605.html#481605 Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone
Gone: MY13 RRS 3.0 SDV6 HSE Black Edition, Orkney Grey/Ivory
Gone: MY09 RRS 2.7 TDV6 HSE, Santorini Black/Almond
Post #490200 Sun Mar 06 2016 10:12pm
Fletcher
Yes mines the same . On a side note the heated seats get bloody hot . You could fry an egg on mine .
Post #490208 Sun Mar 06 2016 10:45pm
jpegnall
I noticed the same on mine. Has anyone taken it in for this
Post #490217 Mon Mar 07 2016 8:04am
kilsbm
Given I've just bought the car I will try and get it back in to be looked at. I'll report back if they can solve.
Post #490229 Mon Mar 07 2016 12:24pm
kilsbm
So I spoke to the dealer on this today.
They have had one other customer complain about - in that case they resorted to getting an identical spec RRS and road testing alongside, only to find that the other car was identical in terms of generating heat in that same place and at the same heat levels (they took measurements).
So sounds like something common and not a "fault" they can do anything about.
I need to decide whether to push it and try and persue or accept this is probably a common issue and little point trying to correct it, and just accept.
Matt
Post #490251 Mon Mar 07 2016 5:33pm
philmw
United Kingdom 2012 Range Rover Sport Supercharged Sumatra Black
Not a fault. Mine gets hot there too.
Post #490252 Mon Mar 07 2016 5:35pm
fkarim
TBH at worst it is an inconvenience that can be avoided by repositioning the leg a little bit. If they need to take things apart to find and insulate the source of this heat then I would prefer to live with it rather than risk getting rattles that didn't exist before! Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Post #490254 Mon Mar 07 2016 5:42pm
kilsbm
Agree
It's something I can live with if I know its not something peculiar with my car alone ....!
Thanks all.
Post #490255 Mon Mar 07 2016 5:47pm
