Home > Faults & Fixes > Suspension fault C1A20-64 - how to fix
Page 3 of 4 <1234>
wings21660
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Fuji White
sorry about the late reply been away on a trip, the guy you need to contact is Gruodiz on this site he lives in Lithuania I sent him the money, the parts came my mechanic fitted it great job done. If you have any trouble in locating him pm me I will try and find him for you good luck Thumbs Up
Post #486089 Sat Jan 30 2016 9:30am
mnk
I bought a full repair kit from X8R.co.uk
https://x8r.co.uk/index.php/catalogsearch/...ange+rover
Post #486131 Sat Jan 30 2016 4:19pm
jase100000
United Kingdom 2007 Range Rover Sport TDV6 HSE Zambezi Silver
I have a v similar issue to this. I haven't checked my compressor yet. Also my car sinks on the suspension if it is left for more than 24 hours, is this the same fault.
Where can I purchase one of these modified compressor lids from?
Post #490385 Tue Mar 08 2016 6:35pm
shakeapaw
https://x8r.co.uk/index.php/catalogsearch/...ange+rover, or Ebay 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #493113 Fri Apr 08 2016 12:50am
Tim in Scotland
If you are not lowering it to access mode and then double locking it then it will lower itself slowly as double locking also sends all the systems into sleep mode which helps conserve the battery when parked up for a long time. After parking it you might even hear it give a short "sigh" after locking, this is normal. If you lower the car to access height then it won't lower any further. If you think that you might have a sensor issue than on the nav screen select the 4x4 off-road screen and you will see the height sensors above each wheel showing as white bars on the screen, a fault will show as one of those bars showing red.
It is also possible that one of the rubber "doughnuts" might be slightly perished and leaking - in this case the compressor may be running a lot and you might get the leveling inoperative for periods while the compressor cools down, you will get a warning in the dash info screen to say that the compressor is overheating in the case of it running too much. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #493126 Fri Apr 08 2016 9:02am
waduk00
need it
I need it, pm email not answer
Post #505489 Thu Sep 15 2016 5:17am
shakeapaw
I'm not sure I understand what you mean? 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #505490 Thu Sep 15 2016 5:31am
driver123
United Kingdom 2006 Range Rover Sport TDV6 HSE Tonga Green
what a cleaver bit of engineering ineed one as i have this problem with my 2006 rr sport
Post #524891 Sun Apr 30 2017 12:53am
jaf901
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Java Black
hi,
do anyone know any Garage can replace this kit for me in London sound like a bargain and clever engineering ? i was advised by RR London to change the whole compressor for £920 , what a rip off .
Post #525928 Fri May 12 2017 11:32am
DrewRRS07
Canada 2007 Range Rover Sport Supercharged Java Black
Need this part
Just wondering if this part is still available as I have a crack in this exact location
Post #558232 Tue Jun 05 2018 10:29pm
pomistea
Ireland 2013 Range Rover Sport 3.0 TDV6 HSE Fuji White
Hi
I'm probably just doing something stupid, but my setup doesn't seem to be the same as the one in the OP's guide.
I can't see anything like the black component with the blue and orange connections.
Mine is a 2012 RR Sport, 3.0 SDV6
Post #625691 Tue Jul 26 2022 9:44pm
I think you will find the difference is because the OP is showing the earlier Hitachi compressor, and your picture is the later AMK type.
Post #625696 Tue Jul 26 2022 11:18pm
pomistea
Hi
Yes, it's the AMK compressor.
Is there a similar known issue / fix for the AMK?
Post #625702 Wed Jul 27 2022 8:42am
So what is your actual fault?
Post #625704 Wed Jul 27 2022 9:14am
pomistea
Hi Col-
Appreciate you trying to help.
it's the same as the one that this thread seems to be about.
The air suspension worked fine til recently. Now, it still works fine a lot of the time, but intermittently gives the error "Only Normal Height Available" and it won't raise or lower.
Post #625705 Wed Jul 27 2022 9:25am
Page 3 of 4 <1234>
