Home > Technical > Two issues - washers and low coolant.
garrycol
Australia
Was on a long drive yesterday and windscreen washers were not working even though I only filled the filler a few days ago. On refilling, I observed water running out the passenger headlight washer - didn't completely drain the tank but lost a reasonable amount. On filling again, water again started to drain but soon stopped. Any ideas??
Also on this drive when accelerating in Sport mode to over take at about 120kph, the low coolant warning would show and then go away. When doing the same in normal "Drive" there is not low coolant warning and on checking the coolant it is fine. Again, any ideas?
Thanks
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #466660 Mon Jul 06 2015 12:14am
garrycol
Australia
No ideas? 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #467106 Fri Jul 10 2015 9:04am
Don't know about coolant but washer issue will probably be non return valve fitted in pipe down by washer jet, just had to do one on mine same issue water leaking out of jet. Need to remove headlamp to can gain access to it.
Post #467145 Fri Jul 10 2015 12:42pm
Bodsy
Site Sponsor
My low coolant message used to come on in the same situation. Then it started coming on more and more often (nothing wrong with coolant levels).
The float inside, becomes porous over time, so it's a common issue, but I think you are at the stage where the float is only a bit porous, but the increased revs, makes the water flow faster and the float is not floating enough to stay up, so the message comes on. You need to replace the whole coolant bottle (there's a newer design). Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #467149 Fri Jul 10 2015 1:03pm
garrycol
Australia
Thanks to both of you for that information - I will check both out.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #467160 Fri Jul 10 2015 2:25pm
sonnyjim
United Kingdom 2006 Range Rover Sport Supercharged Cairns Blue
Sorry to dig up old thread but what's the new design coolant bottle?
Post #485232 Tue Jan 19 2016 4:58pm
Bodsy
Site Sponsor
Its the same design as they have on newer RRS AND d4. Nothing major, just the coolant bleed port has moved. Bodsys Brake Bible
See it HERE
Post #485240 Tue Jan 19 2016 6:00pm
sonnyjim
ok so no amendments to the badly designed float then lol
Post #485247 Tue Jan 19 2016 7:04pm
