![]() | Home > Technical > Two issues - washers and low coolant. |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1070 ![]() ![]() |
Was on a long drive yesterday and windscreen washers were not working even though I only filled the filler a few days ago. On refilling, I observed water running out the passenger headlight washer - didn't completely drain the tank but lost a reasonable amount. On filling again, water again started to drain but soon stopped. Any ideas??
No ideas? 07MY RRS TDV6
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5091 ![]() ![]() ![]() |
Don't know about coolant but washer issue will probably be non return valve fitted in pipe down by washer jet, just had to do one on mine same issue water leaking out of jet. Need to remove headlamp to can gain access to it.
My low coolant message used to come on in the same situation. Then it started coming on more and more often (nothing wrong with coolant levels).
Thanks to both of you for that information - I will check both out.
sonnyjim Member Since: 22 Jun 2013 Location: Kent Posts: 131 ![]() ![]() ![]() |
Sorry to dig up old thread but what's the new design coolant bottle? |
Its the same design as they have on newer RRS AND d4. Nothing major, just the coolant bleed port has moved. Bodsys Brake Bible
ok so no amendments to the badly designed float then lol
