Home > General > rear tail gate struts handed info
mnk
Just my 2pc, the left and right struts are different because of sub-woofer speaker mounted on the right side of the rear door
Post #483846 Sat Jan 02 2016 11:20pm
ABSport wrote:
Just found this
Report post
http://www.tailgatestruts.com have finally replied and want me to send the struts back to them so they can check the pressure in them as it would appear that the struts just need a little bit of extra pressure putting in them.
I advised them that apparently the specs of the left and right handed oncs are different at:
LH 0215WZ 0755N 350/09 CC35
and 6H32-406A10-BB
RH 6759YC F3 0783N 349/09 AD07
and 6H32-406A10-AB
LH = 755 newtons
RH = 783 Newtons
(as indicated within the part numbers above)
L/H BLUE
R/H RED
Post #483848 Sat Jan 02 2016 11:51pm
TubaPlayer
Just triple checked and mine seem to be wrong - that won't be helping 2016 Black SDV8 Autobiography
2013 Grey Black Edition SDV6 (lasted a while but gone now)
2005 Grey Supercharged Sport (gone but never forgotten)
Post #483850 Sun Jan 03 2016 12:13am
ABSport
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
The confusion is LH RH Razz are we talking LH from the back or front of the car Rolling Eyes I think that's what people are thinking. I'd say LH from the rear of the car.
Post #483867 Sun Jan 03 2016 11:05am
O/S and N/S are generally taken from sitting in Drivers Seat or Stood at Rear of Vehicle so Driver side R/H, Passenger Side L/H on R/H/D vehicle Thumbs Up
Post #483870 Sun Jan 03 2016 11:19am
simbad111
update changed struts this morning fitting the red on the right and what a difference, so much better than the crap SGS struts, tail gate now lifts itself slowly, Thumbs Up thanks for the info guys genuine struts is the way
Post #483872 Sun Jan 03 2016 12:03pm
ABSport
That's good. Thumbs Up
I can't believe they are handed though, the subwoofer weighs hardly anything, I know this I had removed mine last week when fitting my tailgate. It actually weighs naff all.
Post #483877 Sun Jan 03 2016 12:43pm
foxtrotzulu
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Buckingham Blue
The tailgate on my 2010 facelift RRS is quite heavy to pull down at first and then shuts with enough force that I've never understood why there is a 'powerclose' feature. When opening you also have to use a fair amount of effort. Do I need new gas struts?
Post #483912 Sun Jan 03 2016 6:54pm
simbad111
i would say so, use genuine struts, i found that using aftermarket ones make things worse,
Post #483950 Mon Jan 04 2016 7:21am
foxtrotzulu
Thanks. I'll change them.
Post #483983 Mon Jan 04 2016 3:30pm
simbad111
Please make sure you support the tail gate with a length of timber before removing either strut
Post #484007 Mon Jan 04 2016 8:03pm
foxtrotzulu
Oh, hadn't thought about that. Thanks.
Post #484137 Wed Jan 06 2016 9:03am
