![]() | Home > General > check brake pads warning |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2021 ![]() ![]() |
You should be fine if the light has only just come on. Just be gentle. * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Ianm Member Since: 23 Dec 2015 Location: St. Albans Posts: 25 ![]() ![]() ![]() |
Must be something in the air (or rather rain) my brake pad warning lights also just come on - but not constantly, must be just on the cusp of needing changing - and I've 600 miles to do before I can get them checked |
I had front discs and pads done recently for £250 all in. Main stealer wanted over £500 |
Crazy money! - I took my defender in for its first (6k mile) service, it took 1.5 hours (including being washed) and cost just over £500!! - bearing in mind it was basically brand new so other than oil & a filter (which can't cost that much) how on earth do you get to £500?? (I accept ones got to make a profit & there are overheads to be paid for)
R444SPT Member Since: 20 Mar 2015 Location: Offroad somewhere Posts: 217 ![]() ![]() |
Never good to check the bill, and see the oil cost, that's probably half the total cost of the service, what ever happened to a 5 litre can for £5 from halfords.... |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4521 ![]() ![]() ![]() |
Its maybe good enough for a Fiesta, but it's not what you would be putting in a £10k engine |
Get that completely, although we are talking about a defender engine here, not the latest much more modern technology available on newer designed engines.m
You would be surprised just how technically advanced the current Defender engine is |
When I had my Subaru Impreza sti I used millers oil & it was & £80 a gallon & I changed it every 5000 miles.
benj193 Member Since: 22 Oct 2015 Location: United Kingdom Posts: 53 ![]() ![]() ![]() |
finally got them replaced, turns out the sensor was cracked... new sensor as well. not a bad price either, all in all £105
Si-W85 Member Since: 22 Mar 2015 Location: Huddersfield Posts: 109 ![]() |
I too have just replaced my pads and wear sensor on the front as the tears were done not too long ago, anyway the check brake pad warning light is still on but goes off when I press the pedal but comes straight back on, anybody any ideas as to why it would do this? Thanks |
sounds like the sensor again... its quite a long cable so could be split somewhere?
I changed them myself I have checked continuity across the new sensor and all is good, I'm thinking I may just do away with it and short out the connector as its driving me mad. I read somewhere that it can take a few trips out before it goes out but I have drove it loads and it's still doing it, also would have thought it either worked or it didn't :/ |
No, it either works or doesn't, no need for multiple trips out. Sounds like you need to check the other sensor, or it's not fully plugged in, or there's a crack (usually where it is angled and goes onto the pad) Bodsys Brake Bible
