![]() | Home > General > Low Mileage vs Later Model |
Pros and cons to both. These cars do like to be used, so very low mileage is not always better. If it were a TDV6 I would be telling you that the earlier ones are better, but the petrols are that much more reliable and AFAIK there's no particular year to avoid for them.
Citizen55 Member Since: 14 Dec 2015 Location: Rollin' in my Five point O (well, 4.2) Posts: 55 ![]() ![]() ![]() |
Yeah cheers - is Adaptive Cruise Control standard or optional extra over normal cruise control on these models? |
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 ![]() ![]() ![]() |
That is the first time I have heard it said that earlier TDV6s are better! |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9087 ![]() ![]() ![]() |
As with all second hand cars, the three most important factors to consider are:
Pretty sure ACC was standard on SC models. ![]()
I meant earlier 2.7s (EU3 05, 06) vs later 2.7s (EU4 07, 08 - but 09 was then better). ![]() (PS: The 3.0 does have EGRs, but they are proving more reliable. ![]() 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 ![]() ![]() |
If you are a low mileage driver yourself then buying higher miles would be easier to justify. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Adaptive Cruise was standard on S/C's and the naturally aspirated V8 petrol from launch, TDv8 also had it as standard. I'm not sure if it became an option on the V6 Diesels after 2010 changes. The problem with the ACC is that it has no fall back to conventional cruise control, once the warning "Sensor blocked" comes up on snowy days then you have no cruise at all until you clean the detector head in the left side of the lower intake, a real pain in the butt when you have ACC and want to do a long motorway haul in the winter when there is slush and snow on the motorways..........
Mine is a MY08 and has the cradle and BT but no electric column adjust. It's an early one in the MY so perhaps these changes were phased? 2012 SDV6 - it's missing a couple of cylinders
My 2007MY did too and it was bought in September 2007 after the 2008MY was launched and I got a whopping discount for taking old and unregistered stock! Up to buying my current RRS2 that TDv8 is the best car and best Land Rover I have ever owned, it was fanastic and everything the RRS diesels should have been from launch. My current RRS2 is that bit better all round though. The TDv8 is also the longest I have ever kept a car and I replaced it with a 2010MY FFRR TDv8 but it just didn't handle so nicely and confidently as the TDv8RRS with the same engine but better brakes and the DR system that the FFRR didn't have then. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
