![]() | Home > Faults & Fixes > Air Suspension Problem |
Cotter Member Since: 11 Oct 2013 Location: Hartlepool Posts: 4 ![]() ![]() |
I was wondering if any of the more experienced guys on here could help with a problem on my 07 RRS 3.6 V8. I have had a bit trouble with the air suspension which has resulted in a replacement compressor getting fitted. The compressor now fires up but the car still sits at access height. On the 4x4 screen in the car it is showing 3 flashing red bars of all wheel apart from the front left. Is it likely that during driving in access mode to get my car home the sensor switches are damaged and need replacing. Any help or advice will be most appreciated. |
Thanks for the comment. As an update I now have car operating and moving to the correct levels with the new compressor. I am not sure if everything is operating as it should. My question is when you park the car up and leave it in normal height should you here the system dump air probably about a minute after you have left the car. I had heard the system prior to changing the compressor occasionally do this but with the new compressor this is notably louder.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9132 ![]() ![]() ![]() |
It's not unusual for them to "fart" some air and settle downwards slightly. 2012 SDV6 - it's missing a couple of cylinders
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2021 ![]() ![]() |
Mine has a little fart now and again on my sloped drive....I guess it's levelling itself after shutdown |
