Home > Faults & Fixes > Air Suspension Problem
Cotter
I was wondering if any of the more experienced guys on here could help with a problem on my 07 RRS 3.6 V8. I have had a bit trouble with the air suspension which has resulted in a replacement compressor getting fitted. The compressor now fires up but the car still sits at access height. On the 4x4 screen in the car it is showing 3 flashing red bars of all wheel apart from the front left. Is it likely that during driving in access mode to get my car home the sensor switches are damaged and need replacing. Any help or advice will be most appreciated.
Post #482339 Sun Dec 13 2015 9:28pm
That would seem to be a reasonable place to start. They're not expensive but the system will need to be calibrated to the new sensors. 2012 SDV6 - it's missing a couple of cylinders
Post #482375 Mon Dec 14 2015 10:54am
Cotter
Thanks for the comment. As an update I now have car operating and moving to the correct levels with the new compressor. I am not sure if everything is operating as it should. My question is when you park the car up and leave it in normal height should you here the system dump air probably about a minute after you have left the car. I had heard the system prior to changing the compressor occasionally do this but with the new compressor this is notably louder.
The system could now be just working to its maximum capacity but just thought I would ask a daft question anyway for peace of mind.
Post #483027 Mon Dec 21 2015 1:48pm
It's not unusual for them to "fart" some air and settle downwards slightly. 2012 SDV6 - it's missing a couple of cylinders
Post #483069 Mon Dec 21 2015 9:00pm
DrRob
Mine has a little fart now and again on my sloped drive....I guess it's levelling itself after shutdown Thumbs Up * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #483072 Mon Dec 21 2015 9:26pm
