Home > Faults & Fixes > Body control unit problem??
Cammy72
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
Hi
This problem started when we had really bad rain in Ayrshire
First the cars heater/blower was cutting off intermittently (switch lights go off and on)
The outside temp bit of the dashboard changes from whatever degrees it is out side to 3 little lines
The hazard lights will flash intermittently
The central door locks will open/close intermittently
Stereo/nav screen cuts out every now and again
Interior light sometimes comes on
Sometimes when trying to start the car it will only lock/unlock the central locking and not turn over the engine
Had the car in st the garage and it was showing loss off communication faults but no one can say for certain what the problem is , I don't want to spend £550 on a body control unit and still have these problems
Any ideas or anyone any experience of this kind of faults?
Any help would be appreciated
Andy
Post #482476 Tue Dec 15 2015 8:13am
Disco_Mikey
You have a CAN BUS issue, which can be quite problematic to track down
Most common place for issues is the TCCM, behind the battery
The IPC has a tendency for a loose connection at its rear. A bang on the top of the dash temporarily cures this, but would not be related to rain
Lots of wiring for the EPB, and RDCM underneath the car
I wouldn't expect it to be the BCM, uses your carpets and/or pollen filter are soaking wet
Essentially, diagnostics is isolating each part of the CAN BUS network, and see if that cures it Thumbs Up
Post #482482 Tue Dec 15 2015 8:52am
Cammy72
You in Ayrshire anytime soon
Post #482483 Tue Dec 15 2015 8:57am
Disco_Mikey
Not until the new year now Sad
Post #482484 Tue Dec 15 2015 9:05am
Cammy72
Ok mate , thanks
Looks like it's the dealer on this 1
Post #482486 Tue Dec 15 2015 9:25am
Cammy72
Is it something you could look at soon or give me a call so I can get more info about when , how much (roughly) and how long it would take you
I'll pm you my mobile number if you can give me a call if you can have a look soon
Post #482494 Tue Dec 15 2015 10:39am
Rrmechbelfast
Northern Ireland 2008 Range Rover Sport TDV6 HSE Lux Santorini Black
Have you checked earths for corrosion, that would be my first port of call If it happened after heavy rain
Post #483317 Fri Dec 25 2015 6:11pm
Evans3373
Wales 2005 Range Rover Sport TDV6 HSE Rimini Red
My car is has exactly the same fault, central locking going on its own, interior lights come on,hazzards stay on, outside temp display goes off, radio and sat nav stop working, and won't start,fitted a new battery first and found a loose earth connection on the inner ns wing, it still faults intermittently ,I can get the fault to go by banging on the top of the passengers side dash board, does anyone know what is under the dash board on the passengers side that is affecting the fault?? I have checked the connections in the engine bay and the connections on the TCCM all look ok, seems to be what ever is high up under the dash ????
Post #485328 Wed Jan 20 2016 11:55pm
Evans3373
At last, found the fault, narrowed the banging on the dash down to tapping on the instrument cluster glass to cure the fault for a bit, it happened more and more towards the end. I suspected the instrument cluster to be at fault causing can bus faults, removed it and stripped it down, found one of the main connector/plug pins at the PCB with a small crack in the solder, just a fresh bit of solder on it cured the whole non starting/can bus fault which I have had for 3
months Thumbs Up [/b]
Post #487833 Wed Feb 17 2016 10:24pm
URX
Scotland
Nice result for the detective work Thumbs Up RRS1 2009 - 2012
RRS1.5 2012 - 2016
RRS2 ...you are kidding right?
Post #487842 Wed Feb 17 2016 11:40pm
Evans3373
Thanks, it took some finding, and the setting up of the temp and fuel gauge needles, putting the instrument cluster back together was a right pain but its back together now working well Whistle
Post #489079 Fri Feb 26 2016 10:06pm
