![]() | Home > Faults & Fixes > Body control unit problem?? |
Cammy72 Member Since: 20 Nov 2014 Location: Ayrshire Posts: 38 ![]() ![]() ![]() |
Hi
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4502 ![]() ![]() ![]() |
You have a CAN BUS issue, which can be quite problematic to track down
You in Ayrshire anytime soon |
Not until the new year now |
Ok mate , thanks
Is it something you could look at soon or give me a call so I can get more info about when , how much (roughly) and how long it would take you
Rrmechbelfast Member Since: 30 Nov 2015 Location: Belfast Posts: 1 ![]() ![]() ![]() |
Have you checked earths for corrosion, that would be my first port of call If it happened after heavy rain |
Evans3373 Member Since: 18 Oct 2014 Location: Buckley Posts: 3 ![]() ![]() ![]() |
My car is has exactly the same fault, central locking going on its own, interior lights come on,hazzards stay on, outside temp display goes off, radio and sat nav stop working, and won't start,fitted a new battery first and found a loose earth connection on the inner ns wing, it still faults intermittently ,I can get the fault to go by banging on the top of the passengers side dash board, does anyone know what is under the dash board on the passengers side that is affecting the fault?? I have checked the connections in the engine bay and the connections on the TCCM all look ok, seems to be what ever is high up under the dash ???? |
At last, found the fault, narrowed the banging on the dash down to tapping on the instrument cluster glass to cure the fault for a bit, it happened more and more towards the end. I suspected the instrument cluster to be at fault causing can bus faults, removed it and stripped it down, found one of the main connector/plug pins at the PCB with a small crack in the solder, just a fresh bit of solder on it cured the whole non starting/can bus fault which I have had for 3
URX Member Since: 09 Feb 2009 Location: Edinburgh Posts: 194 ![]() ![]() |
Nice result for the detective work |
Thanks, it took some finding, and the setting up of the temp and fuel gauge needles, putting the instrument cluster back together was a right pain but its back together now working well |
