![]() | Home > Maintenance & Modifications > Did an oil change today for 1st time nightmare |
Ned Member Since: 25 Jul 2015 Location: London Posts: 100 ![]() ![]() ![]() |
Sorry Andy but I can't help but chuckle I did the same years ago 😀😀😀😀 |
Andym418 Member Since: 16 Sep 2015 Location: South Yorkshire Posts: 9 ![]() ![]() ![]() |
Yes it made a mess. I've always done my own oil changes and servicing as I like to know which oil etc is in and enjoy it when I get time but never ended up with half the oil on the drive. The Mrs isn't too happy. Plenty of newspaper and rags next time |
Well I forgot to put the sump plug back wounderd why it was taking so much oil nearly got a divorce over it 😀. |
Agree it is a silly design. For years now I have always used a massive storage box to catch the oil and even then put big sheets of cardboard over the whole area. Someone at a dealership told me the second plug is something to do with the turbos (maybe the oil feed system?).
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4502 ![]() ![]() ![]() |
For future reference, the oil filter box folds in half, wedges nicely between the sump and chassis, and guides the oil gracefully into the tray underneath |
D/M now that's just giving our trade secrets away |
Cheers Mikey will do that next time.
Change the oil and filter on mine every 5000, use good oil and always drive on light throttle on warm up and let the turbos cool down before turning the engine off (drives the Mrs nuts) sitting there with the engine ticking over but it's cheaper than replacing the turbos. If I ever have problems then it's one of those things but I've done what I could |
I change the oil in my own car every 10k miles. The modern intervals of 15/16k+ is waaaay to long, even for having fancy long life oil If I were running a TDV8, I'd be doing the oil every 6k miles But the post above is also very wise. I do it with every car I own, petrol and diesel, turbocharged or otherwise ![]() |
chopperneil Member Since: 25 Aug 2015 Location: Kent Posts: 55 ![]() ![]() ![]() |
Planning on doing a interim change on mine shortly, have had the oil for a month but no time to do it as yet! as far as doing it on the drive if i lock it in off road height and chock the wheels is that enough space to get under it? I have a couple of axle stands as well that i can put under the chassis just in case!
found a thread detailing the procedure with pics!
The sunshine got the better of me so popped to the local stealer and got the filter and plugs whilst warming up the motor! put it at off road height and put a old double duvet under the front! oil drained without to much mess, ended up using a more rigid piece of cardboard I had to direct the oil but it worked ok, i need a bigger catch can though! Mine holds around 6 or 7 litres so took no risks and interrupted the flow and drained it a couple of times. new filter and o ring fitted and added 8 litres of oil in, let it run briefly and then checked and added another litre, hard to tell on the dipstick where it is but will check it again after a run tomorrow.
DM what's the best oil for a 2012 sdv6 as I'm going to change mine,,I've always used millers oils in the past with high performance engines & changed every 5000 & the oil I've removed as always been as clean as when I put it in..also is it advisable to do a engine oil flush.someone mentioned about 2 sump plugs,has the sdv6 got 2.? Andy. Andy. 21 Ford Ranger Gone but not forgotten Focus RS Red Edition 2015 RRS AB Fuji. 2014 RRS SC Santorini 2016 VW Amarok 2014 RRS AB Fuji 2012 RRS Red Edition Fuji 2015 Nissan Navara 2012 RRS SE Santorini 2008 RRS White 2007 RRS Santorino |
Getting underneath the car is old hat now to drain the oil, I always use an oil extractor, no mess and easy to dispose of.
